[NA] Under the gear boot...
redwards
Postby redwards » Mon Feb 11, 2008 8:03 pm
My gear shift boot has fallen away from knob (or more accurately it's always been like that), meaning the gear stick itself is exposed.
Three questions:
1. What colour (if any) was the stick originally painted? (All I can see is exposed metal and a tiny bit of surface rust)
2. Is the boot supposed to sit flush with the knob?
3. If so, how is it attached?
Former owner of a white 1994 NA8 Clubman
TieNN89
Postby TieNN89 » Mon Feb 11, 2008 8:35 pm
I'd assume it'd be the same as the NBs
my one is exposed because I dont' have the original knob on there
metal is exposed
when i had the original knob in it would screw down hard onto the shift boot
redwards
Postby redwards » Mon Feb 11, 2008 8:54 pm
The stick itself is about 8mm at the threaded end with the knob, and around 20mm near the bottom. The hole in the top of the boot is around 12mm, so it just sort of sits around.
It doesn't look like the knob can screw all the way down, but I'll have another look.
I'm thinking there should be a spring or lock nut underneath the boot that holds the top of the boot hard against the knob.
And I might spray the stick black anyway :)
JBT
Postby JBT » Mon Feb 11, 2008 10:09 pm
The leather/vinyl boot attaches to the underside of the console.
bigdog
King of the kennel
Postby bigdog » Mon Feb 11, 2008 10:58 pm
There's a plastic ring at the top of the boot that sits on top of the tapered section of the lever, which in turn keeps it flush with the bottom of the knob. I would pull the lever out, clean it and paint it gloss black so that it doesn't show when properly installed with the boot and console.
redwards
Postby redwards » Tue Feb 12, 2008 7:57 pm
Thanks everyone!
Yep, a black spray's the go. Looks like the knob needs to be screwed down further too. May as well change the gear box fluid while I'm there.
Steampunk
Postby Steampunk » Tue Feb 12, 2008 8:09 pm
the gearbox is not filled from the gear-stick housing.
The gearstick housing holds a small quantity of oil. Not sure how much, but doesn't look to be any more than 300mL.
Postby Okibi » Tue Feb 12, 2008 8:31 pm
I should have taken photos too, I changed them both for new items about a week ago.
redwards
Postby redwards » Tue Feb 12, 2008 10:48 pm
1red5 wrote:the gearbox is not filled from the gear-stick housing.
I knew that... :oops:
(No really, I did!)
I saw a slide show that someone linked to from a forum here. Saw someone using a nice turkey baster to draw out the fluid from there.
But I'll be doing all that when I get new rubber upper and lower shift boots as well (the upper is rooted, so I assume the lower is too).
Postby Okibi » Tue Feb 12, 2008 11:55 pm
If they arrive before tomorrow afternoon bring them along to the MX-5 club of WA after work get together (details on www.mx5club.com.au) with a philips head screw driver, a flat screw driver and a 10mm socket/spanner and i'll help you swap them across.
I haven't done them on an NA but I don't think it's too different to the NB.
JBT
Postby JBT » Wed Feb 13, 2008 6:51 am
Postby Okibi » Wed Feb 13, 2008 8:30 am
In that last photo, see how the rubber is much smaller than the width of the shaft, rather than try and pull it back off over the gear stick, just cut it off (you're replacing it anyway).
redwards
Postby redwards » Wed Feb 13, 2008 8:21 pm
Okibi wrote:If they arrive before tomorrow afternoon bring them along to the MX-5 club of WA after work get together (details on www.mx5club.com.au) ...
*sniff* I would but I work on Tuesday nights!
Also I need to actually order them at some stage. Speaking of which, any MX5 parts places here in Perth?
Postby Okibi » Wed Feb 13, 2008 11:52 pm
http://www.mx5shop.com.au/ is Perth based.
MX-5 Club of W.A. members get 15% off Parts and Service at Mazda Dealers statewide.
