Hi there,
I have tried adjusting my bonnet so it meets flush with the front bar but it is about 2 mm raised.
The lower striker attached to the frame on the car is adjusted as low as it can go.
The striker on the bonnet seems to be grooved out approx 2 mm. causing the bonnet to be constantly raised.
I have had a look to see If I can remove the bennet striker, it is riveted on but dont think it can be removed.
If anyone out there has a NA can you check to see if your striker on the bonnet is grooved out or is mine stuffed.
How would I fix it a weld job????
Anyone with info would help me out.
NA bonnet slightly raised
- AJ
Yes that is the latch i have the problem with.
It is worn out on the top side some how. I need to fill it with something.
Do you know what they used or did they just weld it and then file down smooth??
Users browsing this forum: Bing [Bot] and 20 guests
