Can you remove the break dust sheild?
wun911
Postby wun911 » Tue Jan 08, 2008 11:41 am
I want to remove the break dust sheild thing that kida covers the rotors. (In a bid to reduce some weight)
I presume the shield has nothing to do with breaking peformance and has no real function other than collecting dust. So I assume its safe to remove them am I correct??
Has anyone done this to save some weight?
Update:
They are removed they dont weigh a lot mabye a couple of hundred grams.
My thoughts are:
They dont have scoops like the front ones to collect passing air.
Keeping water off only one side of the rotor doesent make sence.
I have the same amout of dust with or without them.
Me thinks it acts as a heat shield for when the rotors get super hot.
Removing bonnet strap and leaving it in the tool box next.
every ounce counts
Andrew
Re: Can you remove the break dust sheild?
Postby Andrew » Tue Jan 08, 2008 6:24 pm
wun911 wrote:I want to remove the break dust sheild thing that kida covers the rotors. (In a bid to reduce some weight)
I doubt they weigh very much....but then again every little bit helps :)
wun911 wrote:I presume the shield has nothing to do with breaking peformance and has no real function other than collecting dust. So I assume its safe to remove them am I correct??
I'm guessing that they also help a little with air flow ie: cooling, so you may lesson the performance of your brakes during repeated hard use :?
TieNN89
Postby TieNN89 » Tue Jan 08, 2008 6:28 pm
its brake
they look to me like they are there to move more air to your brake and rotor to help cool them
and i doubt you'll reduce much weight by removing that
it's probably not even 1kg all 4 of them
Postby Okibi » Tue Jan 08, 2008 7:40 pm
They'd also stop puddles splashing onto your brake rotors so help keep the brake discs dry and reduce any warping that may occur when cold water meets with hot rotors.
Mr_Q
Postby Mr_Q » Wed Jan 09, 2008 8:28 am
You can run without them quite safely - they're next to useless. Most people (myself included) who upgrade to larger brakes end up removing or severely butchering them and don't have any problems.
However ... they weigh bugger all. You'll probably lose more body weight during the effort of removing them than the car will lose. :)
Mister Q
SuperMazdaKart
Postby SuperMazdaKart » Fri Jan 11, 2008 12:59 am
how bout getting rid of the stock shields & replacing them with these ones?
fit between the wheel & rotor instead. could paint them, would help to keep the wheels a lot cleaner & they'd hide non painted calipers/rotors too.
http://www.duettomotors.com/miata/kleenwheel.htm
