Armrest in Door
End User
Armrest in Door
Postby End User » Fri Jan 04, 2008 5:59 pm
After noticing the armrest in the pic that TP13SS posted on another topic, I've done some research and found that armrests came standard in the NA1.6's.
Does anyone know if these will fit a NA8 without any modifications?
And, where can I find a set to purchase?
SuperMazdaKart
Postby SuperMazdaKart » Fri Jan 04, 2008 6:10 pm
should fit easy but dunno if you need to maker holes for the 3 screws that go through them?
i find them rather useful too. not only can I put my phone in there but i do actually use them to rest my arm on since the window sill on the door is too high up.
usual places have them, MX5mania, MX5plus, mx5parts.co.uk
marcusus
Postby marcusus » Fri Jan 04, 2008 6:42 pm
Nice phone :)
I've got one too, except I don't use it anymore. The battery's shagged and the slide is cracked on the side so when you push the button, the spring basically dislodges the cover from the rails :P
Back to regular programming...
SuperMazdaKart
Postby SuperMazdaKart » Fri Jan 04, 2008 7:40 pm
well i recently replaced it with a new Sony Ericsson W810i walkman phone :) didn't have enough money to replace the car with a much newer model though..
Garry
Postby Garry » Fri Jan 04, 2008 8:16 pm
The last of the NA8's had them too. My '96 came with them.
End User
Postby End User » Fri Jan 04, 2008 11:29 pm
Cools. I will give Mania a try when they re-open. Lazy buggers!
Steampunk
Postby Steampunk » Sat Jan 05, 2008 7:17 am
That stupid solitary handle and door pocket is the only fugly thing about the NA8. Why oh why did they do this?
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Sat Jan 05, 2008 8:14 pm
Just happened to be going through the shed today and I have a pair of NA arm rests...
End User has first option on them..
$20.
Ajay
Postby Ajay » Sat Jan 05, 2008 8:21 pm
B.A.R.G.A.I.N :)
End User
Postby End User » Sun Jan 06, 2008 12:33 am
Boyracer wrote:Just happened to be going through the shed today and I have a pair of NA arm rests...
$20.
SOLD! Boyracer, I'm sending you a PM now!
