Any Different hard tops available??
Mokesta
Postby Mokesta » Sun Dec 30, 2007 11:24 pm
I've tried the search function here but it blows hard!
Anyway, I'm not the right skin type to be going top-down in Brisbane sunshine and I'd prefer a hard top. The problem is that I've never liked the Mazda wrap around rear window like the factory hard tops (and RX8) have.
So, are there any other brands of hard-tops available that look different? I'm thinking more like the Roadster Coupe style with rectangular back window and small tapering side windows.
M
Alex
Postby Alex » Sun Dec 30, 2007 11:53 pm
there are some aftermarket that have the rear rectangle window instead of the wraparound but I haven't seen any that have the smaller side windows so if you get one your visability will be the same as driving with the soft top up. In comparison the factory hardtop improves rear visability greatly, especially when checking your drivers side blind-spot
Babalouie
godfather of saké
Postby Babalouie » Mon Dec 31, 2007 12:09 am
Steampunk
Postby Steampunk » Mon Dec 31, 2007 1:20 am
[I have dial-up and VERY limited limit so without seeing Babs' link...]
I have seen a couple of CF hardtops on eBay US but without rear glass for some reason. Not sure if it's genuine CF or just a layer.
Same shape as standard.
Muzdaman
Postby Muzdaman » Mon Dec 31, 2007 10:52 am
Carbon fiber Hard Tops come without the window because the glass in a hard top is very heavy and anyone spending the money on CF is probably trying to save weight. You could use glass but most would use plexi glass or Lexan to save weight.
Andrew
Postby Andrew » Tue Jan 01, 2008 10:00 am
what about this one -
Steampunk
Postby Steampunk » Tue Jan 01, 2008 6:23 pm
That one is certainly very different and will definitely turn heads from thte MX-5 community.
PUR157
Postby PUR157 » Wed Jan 02, 2008 12:15 am
One could get away with calling that one a Coupe...
Oneness of Man and Machine
Mokesta
Postby Mokesta » Wed Jan 02, 2008 12:46 pm
That's it!
http://www.simpsondesign.net/Default.htm
In-development... 2003.
M
Ajay
Postby Ajay » Wed Jan 02, 2008 4:38 pm
id buy one!
