How do i look after my roof
- garettb16
aerospace 303 as said above is the shiznit of products
like an armorall but without silicone. instead it has 30spf sunscreen.. its the only thing i use on my dash and roof.
its not greasy at all, you could use it on your steering wheel.
same size bottle as small armorall is about $14. whre armoral is $7
BEST BEST
BEST BEST
- adamjp
If your roof is cloth, not vinyl, Mothers/Meguiars and Autoglym make cleaners specifically for the roof material.
If your roof is made from vinyl, pressure wash and then apply Youngs 303.
Adam
- ducktape69
1red5 wrote:Never heard nor seen this 303 product. Must check it out.
Would it work on tyres as well?
I reckon it would do the same thing for tyres that it does for roofs. Soaks into them, brings back the black and makes them shiny and slippery. I wouldn't go there.
- adamjp
I am certain that my grandfather is turning in his grave over that one. As a spray painter for 40 years, armourall was the bane of his existence.
Never put it on tyres - ever.
Use tyre stuff on tyres, use vinyl protector on vinyl. 'nuff said?
Adam
- garettb16
- sabretooth
- Vehicle: NA8 - Turbo
manga_blue wrote:1red5 wrote:Never heard nor seen this 303 product. Must check it out.
You're not meant to put it on the tread...
- blackster
Care to share which shops stock it, i havent had much luck finding it at supercheap or autobarn locally.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
