Junk in your trunk. well not there, in your front 1/4 panel
Steampunk
Postby Steampunk » Sun Nov 25, 2007 7:18 pm
This is actually something that Terry aka Tezzax5 suggested.
The bottom of your front quarter-panel collects debris.
Not sure if this is a problem with NB and NC models, but it certainly is with NA.
There are 2 bolts that are either 12mm or 10mm (Tez's Clubman had 12mm and my povo-pack had 10mm) on the underbody just infront of the door seam, and 2, 8mm/phillips-head bolts in the wheel-well.
Undoing all 4 will allow you to leverage the bottom-rear part of the front quarter-panel.
Get an ice-cream container, place it under the seam, and pull the panel back a few cm.
Long story short, I managed to fill 1/8 of a medium size ice-cream container with debris that got collected in there.
Good tip to help reduce the chance of rust.
Very easy to do ... so do it! :)
Thanks Terry!
Lucky_Luke
Postby Lucky_Luke » Mon Nov 26, 2007 11:24 am
And while you're there, spray a bit of fish oil in there too!
Further reduces the chance.. smells a bit for a day or too but its well worth it!
L.
Steampunk
Postby Steampunk » Wed Nov 28, 2007 9:03 am
Good bbq story DH. I'm just wondering what kind of a mechanic would leave (assuming) a perfectly good Snap-on item.
MXkal
Postby MXkal » Sat Dec 08, 2007 10:36 pm
Water drainage hole behind the firewallto the side. I dropped the cap off my clutch master cylinder down there and had to take off inner gaurd to get it back.
Overkill is an understatement.
sabretooth
Postby sabretooth » Sun Dec 09, 2007 6:56 pm
There have been quite a few threads on this lately. I found a Stanley knife in my guard once - I was wondering where that had gotten to.
Postby Okibi » Sun Dec 09, 2007 11:00 pm
sabretooth wrote:There have been quite a few threads on this lately. I found a Stanley knife in my guard once - I was wondering where that had gotten to.
I found one in my guard too, not the type I ever would have owned, I blame Mazda :lol:
Steampunk
Postby Steampunk » Mon Dec 10, 2007 9:01 am
I feel jipped now ... all I found were leaves and dirt.
MX5CHIC
Postby MX5CHIC » Mon Dec 10, 2007 8:33 pm
I found placing neatly cut plastic mesh at each side of the panel below the windscreen prevents leaves from building up in the guards.
Without the leaves in there I have noticed that there is no longer any dirt / mud buildup ..... cool, gas and groovy.
Users browsing this forum: Jeo and 3 guests
