Malibu Paint...
- Ajay
Malibu Paint...
Hey Guys..
just about to have those Side Skirts resprayed.. just need to find a place around Sydney's Western Suburbs that can mix the paint for me.. i know the code (HZ) but on the touch up paint i have it it doesnt have a mix # does this mean i will have to get someone to custom mix this?? sorry i dont know much about paints..
cheers
ajay
cheers
ajay
- Benny
JBT wrote:I think that colour is yellow misted over a white base - could be fun matching it.
I think you're right JBT.
I remember Bob Hall talking about it one day saying that the factory hated to do the yellow Malibu colour as the bodies first had to be painted white, then they had to get them off the production line and manually re-insert them into the paint line to get the yellow put on top of the white the next day.
- Ajay
- Ajay
- jules
- Guitar Hero
It's a total pain.
JBT is right, the yellow is just misted over the white. What you are seeing is white through transparent yellow. It's a very bright colour.
Spray painters (even very high end one's) can match the yellow very nicely, but if you get the car under a flouro light, you will see where the original paint and the new paint is, as the flouro really draws out the white in the paint.
Juffa, is that why you resprayed yours?
Jules
Jules
Jules
While Tweety was in the shop getting the front end fixed I asked Dick to patch up a couple of door dings and then one thing lead to another and in the end it made more sense to re-spray the whole car as I was concerned that she would end up patchy.
J
Ajay, Have a chat with the spray painter and see what they suggest. If you are just painting skirts this might not be as easy to notice as say one of the larger panels?
- bigdog
- King of the kennel
- Ajay
- Boyracer
- MX-5 Encyclopedia
- AJ
TP13SS wrote:that wasn;t the comment i thought i would hear from you.. i thought it would be..
buy an SP..![]()
thanks for your help guys.. i will see how i go.. (cant afford to spray the whole thing)
honestly Ajay........with Jules car in any form of light OTHER than flouro, you wouldn't pick it at all, his looks the ducks guts, last week was the first time i'd seen it under full flouro light & you could see it straight away, but only because the light drew the base coat (white) out, you can even see where the misted yellow was a bit light on with the factory paint, it was weird...........just colour match it with the solid colour, being skirts, you won't even notice it mate
XMX5 Rogues
- Ajay
- bigdog
When I did mine I just painted over the black. Not a good idea as it took a lot of paint and has a greenish tinge. Just finished my rear deck cover using primer filler (a light tan) and it came up a treat. Colour is HZ and I used a small aerosol pressure pack from Bunnings. If you use this you need to thin the paint out a bit more than recommended...an easy diy job though..
NB SE, NA 1.8.
