Door Top Moulding Replacement (lots o' pics)
Posted: Sat Nov 10, 2007 12:01 am
One of the things that's bugged me for a while is the manky state of my doortop mouldings. As any NA owner will know, they go all bleached and ripply, then little bubbles pop up as the metal insert inside the moulding rusts....you can polish your doors to death but you still will notice that horrible zombie moulding at the top.
But you can buy replacement ones from Mazda and they're just a touch over $50 per side. Replacing them is easy as pie.
First you prise out the little plastic stud that holds each end in place (there is another one at the front of the door)
Now forcibly peel back the moulding. You'll be bending it beyond repair but you're chucking it away anyhow...see that clip? Poke in the little tab in the middle of it with a screwdriver and pull it out of the door.
There's a few...I removed my mirror to make it easier, but I think you could do it with the mirror in place if you were careful.
There is a fair bit of gunge trapped under there...
New vs old moulding
Removing the old one has really ruined it but the new one is perfectly straight!
Bit of Meguiars lovin later and it'll look like this...
Popping in the new moulding is a 10second job
Bewdiful
I reckon 30mins of your time and $100 later it's a huge improvement to any NA with old wonky door mouldings.
New vs old moulding
Bewdiful
