Door Top Moulding Replacement (lots o' pics)
Babalouie
godfather of saké
Postby Babalouie » Sat Nov 10, 2007 12:01 am
One of the things that's bugged me for a while is the manky state of my doortop mouldings. As any NA owner will know, they go all bleached and ripply, then little bubbles pop up as the metal insert inside the moulding rusts....you can polish your doors to death but you still will notice that horrible zombie moulding at the top.
But you can buy replacement ones from Mazda and they're just a touch over $50 per side. Replacing them is easy as pie.
First you prise out the little plastic stud that holds each end in place (there is another one at the front of the door)
Now forcibly peel back the moulding. You'll be bending it beyond repair but you're chucking it away anyhow...see that clip? Poke in the little tab in the middle of it with a screwdriver and pull it out of the door.
There's a few...I removed my mirror to make it easier, but I think you could do it with the mirror in place if you were careful.
There is a fair bit of gunge trapped under there...
New vs old moulding
Removing the old one has really ruined it but the new one is perfectly straight!
Bit of Meguiars lovin later and it'll look like this...
Popping in the new moulding is a 10second job
Bewdiful :)
I reckon 30mins of your time and $100 later it's a huge improvement to any NA with old wonky door mouldings.
garettb16
Postby garettb16 » Sat Nov 10, 2007 12:28 am
looks fantastic... good call mine are rank aswell
looks even better with those sweet mirrors
Richee
Postby Richee » Sat Nov 10, 2007 7:31 am
I was just looking at mine yesterday and thinking I should replace them, now I know how easy it is I must get on to it. Thanks Babs
Mazda Tribute - its a boat
Gazbo
Postby Gazbo » Sat Nov 10, 2007 8:53 am
I replaced mine a month or so ago, one of the clips missed the holes when I was attaching the new moulding. It's very tough to remove the new moulding without bending it, so make sure you get it right first go!
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
Boags
Postby Boags » Sat Nov 10, 2007 9:45 am
Group buy? :mrgreen: :lol: :roll: :oops:
(I'm kidding, you get a discount from some Mazda Parts places if you are a club member anyway.)
Boags
Captain Spank
Postby Captain Spank » Sat Nov 10, 2007 11:15 am
That is so weird, I was apply black tyre paint last night to my wheels and thought, hmmm I wonder if this tyre stuff will spruce my door mouldings up. Does the job alright, but certainly doesn't look as shmick as yours. Might go fork out the cash now instead.
Rice, rice baby. NA6 on the road to bling.
GP
Postby GP » Mon Nov 12, 2007 1:03 pm
Group buy?
Sounds like a good idea to me :D
Graham
wun911
Postby wun911 » Mon Nov 12, 2007 4:13 pm
I have an NB with windows that rattle a bit when I go over a bump or rough road.
Does replacing the door moulding fix this issue? Is it the same procedure and part number for the NB?
every ounce counts
Babalouie
godfather of saké
Postby Babalouie » Mon Nov 12, 2007 4:37 pm
Rattly windows is more likely a worn regulator.
As the window goes up and down, the glass pane slides up and down this rail inside the door. A plastic wheel normally rolls within the rail, but over time it can crack and fall to pieces, so the window pane is then free to rattle against the rail.
I hope you are sitting down when Mazda tells you the price of a new regulator though :)
I have this problem in the Luce, it looks like if you could pop in another plastic wheel (and no they aren't sold separately so you need to get it made) say fashioned out of nylon it would do the trick. Haven't done anything about it tho.
But yes it's the same process for replacing the NB part. In fact Mazda doesn't have stock of NA ones anymore and the one I fitted to my car is an NB8C item.
Users browsing this forum: Jeo and 3 guests
