Anyone tried moving the HVAC controls in their NB?
sabretooth
Postby sabretooth » Fri Nov 09, 2007 11:54 pm
As per the topic, has anyone tried moving the controls for their heater, ventilation and air conditioning to another spot in the dashboard? It seems to fit multiple places, but I'm wondering if you moved it and whether or not moving it affected cable operation.
phatR
Postby phatR » Sat Nov 10, 2007 12:40 pm
A friend of mine moved is hvac to the glove box but it wasnt a mx5
I think there is quite a lot to do
sabretooth
Postby sabretooth » Sat Nov 10, 2007 1:31 pm
I mean vertically inside the dash where the tray, radio etc go too. Thanks though.,
Fatty
Postby Fatty » Sat Nov 10, 2007 1:36 pm
i've been thinking about the same thing for my NA.
marcusus
Postby marcusus » Sat Nov 10, 2007 3:49 pm
I don't know that the cabling would stretch. The cable which controls the hot/cold setting of the NB8A doesn't have much spare length in it. You could always try and extend it, but then you run the risk of the cable snapping after a lot of use at the join point. I think that and the control for where the air is to be directed would be the ones that will cause most grief.
The unit itself could easily be moved. It's just a matter of these cables.
Users browsing this forum: Jeo and 3 guests
