Small cracks in rain rail - a problem ?
meanmx
Postby meanmx » Thu Sep 06, 2007 10:55 pm
I stuck gaffa tape on the couple of little cracks on mine. No problems with it yet.
Ben
2014 VW Mk7 Golf R
Garry
Postby Garry » Fri Sep 07, 2007 10:32 am
What Ben said. Seal them up with gaffer tape before you install it. If they are only small the tape fix should be fine.
Juffa
Postby Juffa » Fri Sep 07, 2007 10:51 am
Yep, what Ben and Garry said. I used good quality cloth backed tape to seal up the rain rail on two of my MX-5s. After reinstalling the roof pour water around the bottom of the rear window and make sure the water is flowing out of the small drain pipes in front of each rear wheel and there is no water getting into the cabin.
J
Juffa
Postby Juffa » Fri Sep 07, 2007 12:42 pm
Pumpn'Go wrote:Sounds dumb , but what is a rain rail?
Search and ye shall find....this is just one of many discussions on the subject.
http://www.aus-cartalk.com/viewtopic.ph ... 0bac13b887
J
