Advice Needed: NA Dash Replacement
Jimmy
Postby Jimmy » Thu Aug 23, 2007 12:21 am
Well, removing the dash and instrument cluster is the easy part. Should take about an hour. The hard part is putting the new dash back in. This can take hours and lots of swearing. Although i havent done a dash replacement on my five, ive done a few on some corollas and in total i would say it took 4-5hours (also being the first time i had done this) The bit which got me was when the dash was back in, i was left with numerous nuts and bolts which i have no idea where they came from so probably worth noting which bolts/nut came from where. Overall, its a reasonably straight forward job, just very time consuming.
Hope this helps.
Captain Spank
Postby Captain Spank » Thu Aug 23, 2007 12:43 am
These threads from miata.net may help you a bit;
Sticky Dash
Odd dash fix
CS
meanmx
Postby meanmx » Thu Aug 23, 2007 5:44 pm
Really sorry for the thread hijack but Jimmy J5 I love the picture in your sig. Sorry end thread hijack.
On topic, dashes are easy enough but are time consuming for the first timer. After a couple you'll be whipping them in and out in no time :D
Ben
2014 VW Mk7 Golf R
