Air Vents
Rooster
Air Vents
Postby Rooster » Fri Aug 17, 2007 5:56 pm
Hi Fellers,
The air vents on the dash of my 2002 MX5 slowly vibrate down after a few k's any simple remedy other than jamming something into them? :?
The Rooster
Ajay
Postby Ajay » Fri Aug 17, 2007 6:01 pm
i believe they have a piece of foam at the base (that keep them firmly in place) this wears away after time.. maybe pop the air vent out and take it apart and have a geez :D
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Fri Aug 17, 2007 6:01 pm
Pull them apart and replace the little felt pads that stop them from drooping.......
It's an easy job even for the tech challenged.....
Ajay
Postby Ajay » Fri Aug 17, 2007 6:18 pm
thats what i mean FELT not foam.. thanks UA
Rooster
Air Vents
Postby Rooster » Fri Aug 17, 2007 8:53 pm
Thanks fellers
I knew I would get good advice, I will check tomorrow and see if I can remove them without too much agro. :oops:
Captain Spank
Postby Captain Spank » Fri Aug 17, 2007 9:30 pm
Best way to pop them out is with something like packing tape (you know the blue plastic strip stuff you find large around cardboard boxes that you need a knife to cut off). Thread that through and loop it back and then give it a 'solid' direct pull...may help to put knees or feet on dash in some cases.
Don't use wire as it's too thin and will dint & bend the back part of the vent balls plastic.
Just a tip I learn't through trial and error. :D
Pretty easy job though, have fun.
CS
jules
Guitar Hero
Postby jules » Fri Aug 17, 2007 9:35 pm
Sometimes you can get away with just pushing them in a bit. It holds them a bit tighter.
Jules
Alex
Postby Alex » Sat Aug 18, 2007 1:18 am
I'm amazed that i haven't had this problem, if anything mine are too hard to move, expecially the centre ones :?
RG.net
Postby RG.net » Sun Aug 19, 2007 11:15 pm
mine sag like to tomorrow!
i push mine in but 2 mins later they droop again, where do you get this \"felt\" from? mazda i presume :roll:
Bevan
Postby Bevan » Sun Aug 19, 2007 11:28 pm
Crocaine wrote:mine sag like to tomorrow!
i push mine in but 2 mins later they droop again, where do you get this "felt" from? mazda i presume :roll:
Try Lincraft or Spotlight... :P Just ask for some sticky felt. 8)
ampz
Postby ampz » Mon Aug 20, 2007 7:54 am
Bevan wrote:Try Lincraft or Spotlight... :P Just ask for some sticky fur. 8)
:shock:
Chew Bakka Outfit? :P
(hides) :lol:
Huh?
Garry
Postby Garry » Mon Aug 20, 2007 10:32 am
Bunnings sell it too.
