Bugger... cracked rear window
Ok, did a bit of a search but that turned up nothing, anyway, I was putting the roof up and saw a big tear in the plastic rear window. Kinda my own fault, I had not been unzipping it properly, only half way - reason for that is the stitching in the passenger side corner when zipping it up around the bend seemed to be a bit loose, and I was concerned about that tearing. But now I have the new issue of a big hole in the back window. Is there somewhere I can get just a replacement window piece? The rest of the roof is fine, so I would prefer not to replace the whole thing, plus the cost of the new roof would be a lot more. Any ideas? Ideally I would like to put a glass window in, but I doubt that is going to work in the original type.
- StanTheMan
You can...... but be aware standard top Has a differnt size zipper to the Robbins aftermarket.
The upholsterer in Brookvale will want to charge you around $400 for a new rear window. or $500 for a 2nd hand one completely fitted. in which case you may want to look for a ebay one.
you can try mania if they have any spare rear windows. Just check the size of the zipper.
Buy a second hand glass window top with Frame, easy swap over (apparently)
I think someone here wants to get rid of his, also check out Mania they usually have some.
Richard
Richard
Mazda Tribute - its a boat
Richee wrote:Buy a second hand glass window top with Frame, easy swap over (apparently)![]()
Richard
Will give Mania a call, see what they have. Although it may be time for a new roof anyway, don't think it is properly waterproof any more, got what appears to be a bit of mold maybe starting on the inside - will have to get that cleaned up. Here is a picture anyway of the window...
- bruce
- Vehicle: NA8 - Turbo
