Hi all
have just aquired a lovely s/s instrument bezel (surround) and need info on how to remove dash etc to instal.
Tried a search but to no avail.
Any help greatly appreciated. For a 2002 NB8B
Robbiew
Instrument cluster removal
- Bevan
1) Remove the 2 screws from the underside of the steering column shroud.
2) Seperate and remove steering coloumn shroud
3) Grad the \"hood\" of the instrument cluster and give it a few very firm tugs. After the initial \"pop\" remove the hood carefully
4) There are 4 screws that hold in the actual instrument cluster. Undo them and the cluster comes off.
This is as far as what i've needed to go. It seems there are many tabs around the cluster that need to be popped off to take the clear plastic face off.
Good luck and post pics!
Bevan
Bevan
- jules
- Guitar Hero
instrument cluster
i bekieve that there are two types....one where the plastic cover is glued on and the other is attached by tangs....is the NB8B a \"tang\"version?
robbiew
robbiew
- Bevan
Re: instrument cluster
Never heard of a tang before, but I think our cars have them (if you mean the plastic tabs).robbiew wrote:i bekieve that there are two types....one where the plastic cover is glued on and the other is attached by tangs....is the NB8B a "tang"version?
robbiew
It literally takes less than 5 minutes to do thos steps above so your best bet is to take it out and have a look yourself.
Bevan wrote:Never heard of a tang before, but I think our cars have them (if you mean the plastic tabs).robbiew wrote:i bekieve that there are two types....one where the plastic cover is glued on and the other is attached by tangs....is the NB8B a "tang"version?
robbiew
Thanks, Bevan
will have a go this weekend and let you know
with pics !!
- ampz
- Vehicle: NA6 - Turbo
Bevan wrote:Never heard of tang before
Orange powder you stir a couple of teaspoons in a glass of water and add ice.
Yum
Huh?
- Bevan
ampz wrote:Bevan wrote:Never heard of tang before
Orange powder you stir a couple of teaspoons in a glass of water and add ice.![]()
Yum
