Hi all,
Does anyone know how to remove the plastic trim on the A Pillar?
This is for NB8B btw...thanks.
Removing the plastic trim on the A Pillar
- AB7
- Garry
Remove the rubber door seal, the sun visor and unclip the end of the plastic header cover. There is a tight fitting metal clip up near the top of the plastic A pillar cover, a round plastic locating pin and a plastic tab down near the bottom that fits into a rectangular hole in the A-pillar. So unclip the top clip then pull out a bit and up.
