My new seats
meanmx
My new seats
Postby meanmx » Thu Jun 21, 2007 9:50 pm
Hi all. Just thought I would share a couple of piccies of my new seats. They are recaro rip-offs but they are adr'd so I would presume they are reasonably safe. They were an absolute pain in the ass to fit especially the passenger one but thanks to many posters on this forum I got it sorted out in the end. They are very, very tight and I even had to take the plastic cover from around the adjustment lever off so that I could fit them in. A couple of early thoughts -
They are an awesome mod
I need to lose a little weight
I'm a bit concerned about some of the high wear areas ie where the seatbelt strap slides over the shoulder. But I will worry when the time comes
Red is ridiculously easy to mark
My car feels faster now
You sit a little bit higher in these. Just as well I got a flat bottom steering wheel
They were well worth the money and thanks goes to my wife for buying these for my anniversary even though she didn't want to. I know some people wont like these but everyone to themselves. I like them alot.
Ben
2014 VW Mk7 Golf R
Alex
Postby Alex » Thu Jun 21, 2007 10:00 pm
I like them because they can recline :D
RG.net
Postby RG.net » Thu Jun 21, 2007 10:41 pm
goddamn, your interior is so sexy, seats are awsome mate, hoping to put some in mine soon, if not just get a retrim :)
Craig
Postby Craig » Thu Jun 21, 2007 10:46 pm
Hmmm somebodies got a red fetish! :lol: 8)
ampz
Postby ampz » Thu Jun 21, 2007 11:01 pm
It beats a brown fetish :shock: :P
Looking good mate. :)
Huh?
Craig
Postby Craig » Thu Jun 21, 2007 11:11 pm
ampz wrote:It beats a brown fetish :shock: :P
D'oh! :lol: :oops: :P
deez
Re: My new seats
Postby deez » Fri Jun 22, 2007 1:01 am
bdscott wrote:Hi all. Just thought I would share a couple of piccies of my new seats. They are recaro rip-offs but they are adr'd so I would presume they are reasonably safe. They were an absolute pain in the ass to fit especially the passenger one but thanks to many posters on this forum I got it sorted out in the end. They are very, very tight and I even had to take the plastic cover from around the adjustment lever off so that I could fit them in.
Hi Ben...I'm eyeing off some Justjap seats too....those looks awesome in your 5 8) Can you possibly point me in the direction of some info on installing? eg on issues encountered....or if you have like a thread here where you posted all your install steps etc that would be awesome :) (I tried to find it yes....alas it was not fruitful)
Do they sit a lot higher than standard seats? If not how much roughly?
Thanks heapssss
Derek
89 Eunos Roadster
deez
Postby deez » Fri Jun 22, 2007 1:03 am
Oh and also....any clearance left on either side of the seat? If so how many cm's approx?
Those Recaro copies are quite narrow already....I was eyeing off the Bride copies which look a bit wider so I'm not sure if those will fit now... :?
Thanks.
89 Eunos Roadster
green_comet
Car Detailing Guru
Postby green_comet » Fri Jun 22, 2007 4:13 pm
Seats look good Ben, you should look at colouring the inside of the seats black to break up the red a bit.. will also be harder to stain..
Nice mod.. :mrgreen:
meanmx
Postby meanmx » Fri Jun 22, 2007 6:02 pm
Thanks for all the comments guys.
Is this what they do in the states? :lol: Seriously I was looking at the red/black ones which have black on the sides and red inside. But when I eventually found a place that sold them he had either red or black. I was worried the red would be too much but in reality they look pretty good and tie the red in the interior together nicely. As for the staining, it's just as well I still had the old seats in when I took Stu down the Great Ocean Road :lol:
Thanks for the comment Derek. You ask most of the same questions I was contemplating before I bought mine. I got most of my info from this thread so thanks to all who contributed http://www.aus-cartalk.com/viewtopic.php?t=24726. I didn't really want to post up how I did it as there are a few critical people on here who will no doubt find fault with what I did but it sucks being left in the dark so I will try.
The drivers side was very easy. The front of the rails use the same holes to go up into the seats but the rear holes have to be drilled about 15mm closer to the front (this is not an exact measurement. You will see when you go to do it). Then it's a matter of just bolting it in.
The passenger side was a lot more difficult as the seat holes are wider than the car holes by about 15mm. I had to basically elongate the holes where you bolt them into the car by about 7mm each side front and back with a dremel. It took a long time to do this but be patient. I then had to get slighty longer bolts to bolt them in. Off the top of my head the bolt thread is 10 x 1.25.
The seats were a very tight squeeze to get in and there is absolutely no room on each side. As mentioned I even had to remove the plastic cover around the seat adjustment lever to fit them in! That's tight :shock: . I found that I was probably about 3-5 cm's higher afterwards. If you are over 6 feet I do not recommend these. Also you might want to consider a flat bottom steering wheel.
I was looking at the bride style as well but I went with the recaro because I think they are sexy as. I believed that the recaro and bride were about the same width but you might want to take a tape measure to it. The bride was softer so may be a bit more comfortable. They look great from the back with the roof down 8) . Hope this helps.
Ben
2014 VW Mk7 Golf R
Postby Okibi » Sun Jun 24, 2007 12:53 am
Lookin good Ben
Alex
Postby Alex » Sun Jun 24, 2007 1:29 am
looks good, you got the best colour of all, RED, get a harness to go with them maybe :P
Love those number plates as well
Postby fastfreddygassit » Sun Jun 24, 2007 9:38 am
Mate, that car is coming together really, really well!! 8) 8)
The seats look maaaad!
Great stuff, cannot wait to see if my fat-ass fits in (shut up ryan)
:mrgreen: :mrgreen:
meanmx
Postby meanmx » Mon Jun 25, 2007 6:58 pm
Yeah they hit everything everywhere but from the looks of it, it is pretty normal. Something I am very willing to accept. In fact I had a look at your car on the GOR run and decided that they were fine. That's what made me decide to get them. They also rob me of a fair degree of rearward travel. I think if you were over 6 feet tall there is no way I would do this. I'm 178cm and I make it just with the flat bottom steering wheel.
Ben
2014 VW Mk7 Golf R
green_comet
Car Detailing Guru
Postby green_comet » Mon Jun 25, 2007 7:12 pm
fastfreddygassit wrote:Great stuff, cannot wait to see if my fat-ass fits in (shut up ryan)
:mrgreen: :mrgreen:
Image Image
