Mmmmm . . . Brad, give me a ring and lets organise a get together.
The water is an easy fix . . . wire to clear the drain holes front and rear of the sill . . . squeak may be beatable too.
A couple of annoying things.
- RRdstr
- Captain Spank
Funny I'm having the same water issue. When I stop at low speed I'm hearing a splashing sound around the left door/front area.
I've cleaned out my rear drain sills. And the door drain hole is dry, could it be blocked further along the door?...I could remove the door trim to investigate further.
I had a similar squeeking issue but with my soft top along the front. Adjusted the hex nuts on the locking clamps to tighten the fit when closing the roof. Unsure about the hard top...still yet to grab one.
- Garry
The hardtop has adjustments at the front latches the same way the softtop adjusts.
It also has adjustment shims under the rear chrome covers on the hardtop. There is a small phillips head screw on the side of the chrome cover to open the cover.
With the hardtop mounted onto the car undo that screw and swivel the chrome cover out of the way. You will see 2 bolts holding the adjustment shim in place. Loosen the bolts and move the shim around to the optimum position. Sometimes the plastic coating wears off the shims which also causes squeaks as the shim rubs against the hardtop post. Removing the shim and flipping it over so that the worn plastic faces down may help this.
- deez
Garry that's awesome. My hardtop is squeaking and rattling pretty badly over bumps....think I'll take all the clips apart and try and adjust them
Garry wrote:The hardtop has adjustments at the front latches the same way the softtop adjusts.
89 Eunos Roadster
