Posted: Sat Apr 21, 2007 7:48 pm
by lowmiata
what sort of roll bar is it?
If it is similar to the brown davis you wont need to remove the hood or the carpet
rules state there cant be anything flamibale etc between the bar and the body ie plastic trim or carpet
you can leave about 10mm of carpet under the flanges so the carpet stays down
carpet and trim is cut away on mine only place i didn't cut the carpet was under the big plate that goes right across the back
but ther is no bolt fittings in this location anyway
main thing really depends on what type of bar it is
ie does it go into the boot?
and right down behind the seats?
fi its a BD it wont have either of the above
Ryan.
Posted: Sat Apr 21, 2007 10:11 pm
by bigdog
The following link will give you a photographic guide to intalling a Brown Davis bar in both NA and NB models, assuming this is what you are fitting. Enjoy!
link to pdf
Posted: Sat Apr 21, 2007 11:54 pm
by lowmiata
lam.666 wrote:thanks ryan,
i have no idea what brand of bar it is, its not a BD, but was told that its a cams approved bolt in...
to my understanding most cams cages need to be welded?
anyways... the main hoop bar is positioned behind the seats, and then it has two bolt on bars which extend and attach to the parcel/rear shelf
when your talking about rules, those are CAMS rules ur talking about?
Cams and DOT
as long as it doesn't have side intrusion bars on the cage ie going to the dash board otherwise it sounds fine
can be bolted in for cams as the BD is, unless the rules have changed
Posted: Sun Apr 22, 2007 12:26 am
by zoomzoom
Pretty sure you will find that cams no longer allows many bolt ins at all except for the BD bar for eg which you must have the cams certificate when you get the bar, that said, if you are doing any cams event, unless it is stated in the supp regs, you can use any bar at all.
