Hey Guys..
does anyone have any ideas on what types of clips to get to anchor my floor mats (stop them sliding)..
i was thinking of putting a clip under the carpet facing up and through the mat.. has anyone done this for an NA?.. or where i can get clips to do so..
Ajay
Floormats
- Ajay
- Alex
I've just got the ones that came with the NB but you already know that
you could use velcro (the scratchy side) on the underside of the mats to stop them sliding you would only need about 2 short strips (one at from one at back)
otherwise see if the NB ones would work you would need to lift the carpet to see if you have the right hole for mounting them, it would be on the raised bit of metal that the front seat mounting bolts are in so it might be too much trouble
- sliq
