There is this annoying loud metal rattling sound everytime i hit a pot hole or a bump, sounds like a sheet of metal rattling...
I am still in a process of elimination..... tighten bolts and extra foam on the cai, wedged tight the radiator fan cover, also checked the header's heat shield and in the process of removing the heat shield just above the cat convertor
BTW its a NB8A
anyone else had experienced the same problem?
Mystery undercar rattles
- giro-pilot
- Brett_MX5
Re: Mystery undercar rattles
EGG80X wrote:There is this annoying loud metal rattling sound everytime i hit a pot hole or a bump, sounds like a sheet of metal rattling...
Yep, same thing with my NB8A
I've looked at just about everything and cant find out what is causing it, but it does sound like its coming from the rear of the car somewhere
Its not the exhaust or the heat shields
"You tried your best and failed miserably,
The lesson is, never try"
-Homer Simpson
-Homer Simpson
- Garry
my car has the same rattle, it's the rear brake pads.
if you have a look you will be missing the retainer clips for the pads.
Or if it's an NB8B the retainer clips have fatigued over time and they no longer do their job.
- Brett_MX5
Daz 27 wrote:my car has the same rattle, it's the rear brake pads.
I'll have another look when I get me car back from Mania
Thanks guys - even tho I didn't ask the original question
-Homer Simpson
-Homer Simpson
thanks for the pointers guys
wot a nightmare, drove me nuts!!! couldn't find the source of the problem all weekend
so I drove upto mania last night and Dave and Daniel were pretty helpful!!! took us a good hour to found that rattle it turns out to be the rear muffler heat shield, it was probably cracked when my car was rear ended and it wasn't repaired.
Once again BIG THANKS to Mx5 Mania
