Windscreen wiper inserts
idb000
Postby idb000 » Wed Apr 04, 2007 12:13 am
Hi All,
I've just been reading the thread about the windscreen washer nozzles and it jogged my memory back to the recent rainy days in Sydney, and the fact that my wipers need to be replaced. I popped in to MX5 Mania on the weekend to see if I could get a new set of wiper inserts, but Simone told me that Mazda had stopped making them. Apparently, the Mazda inserts used to fit perfectly, but now the only option are the generic inserts you get from Repco, Supercheap, etc, that you have to cut to size. I've heard that the Repco ones are not very good. Can anyone recommend where to get a good replacement wiper insert?
Thanks in advance
Ian
2001 Black MX5 NB8B
http://www.idb000.com
Andy Wana
Postby Andy Wana » Wed Apr 04, 2007 1:16 am
I've bought a pair of wipers from Supercrap once ... never again
BOTH of them failed after less than 6 months (plastic extrusion near the metal clips cracked, rendering them useless)
Bought one of them Telfon coated wipers at Repco and they were excellent IMHO
They were quiet during use, smooth in operation, fit very well onto the OE wiper blades and I've not had any problems since
They also have thin metal blades sandwiched between the rubber profiles, making them very strong as opposed to Supercrap's all chintzy plastic construction
Let me sort thru my rubbish in the garage and find the brand for you
If any of you have better suggestions, let me know as well
I ♥ asymmetry
Andy Wana
Postby Andy Wana » Wed Apr 04, 2007 11:18 am
One more thing to add ... I don't have to cut any of the Repco wipers to suit the car
It came in different lengths for different sized cars ... very handy IMHO
I ♥ asymmetry
idb000
Postby idb000 » Wed Apr 04, 2007 12:05 pm
Hey Andy, thanks heaps for the info. I will have a look at the Teflon ones Repco. If anyone else has any other suggestions, I'd be interested to hear.
2001 Black MX5 NB8B
ducktape69
Postby ducktape69 » Wed Apr 04, 2007 12:40 pm
bought some from autobarn. $13 i think. they work great. steer away from the cheaper ones...they r crap
Garry
Postby Garry » Wed Apr 04, 2007 1:21 pm
Because my car is \"special\" in so many ways the cheaper plastic backed ones work much better than the more expensive metal between the rubber profile ones. I find the more expensive ones jump across the screen for some reason. I've tried all sorts and all prices but the cheapy $6 ones work the best for me.
JSE
Postby JSE » Wed Apr 04, 2007 5:41 pm
Repco at Kellyville or Autobahn at Blacktown (Autobahn have some quality ones) ... thats where I got mine with a pretty large range. Hope this helps Ian.
idb000
Postby idb000 » Wed Apr 04, 2007 8:44 pm
Thanks guys for your responses. It has given me an idea of where to look and what to look for.
Thanks again
Ian :mrgreen:
2001 Black MX5 NB8B
bigdog
King of the kennel
Postby bigdog » Wed Apr 04, 2007 10:13 pm
From my own experience in selling auto parts the biggest factor in blade quality is freshness - the newer they are the better they work. Blades sold in supermarkets or servos can be 12 months old before they're used, often exposed to sunlight too. Same as others, I have used cheapies that were great and bought dear ones that were crap, but that probably had more to do with how long they were in the warehouse and shop than anything else. By far the best solution is rainex - if you keep a good coaton the screen you only need to use the wipers once in a blue moon 8)
rjastra2
Postby rjastra2 » Thu Apr 05, 2007 10:20 am
you need some of these....
Garry
Postby Garry » Thu Apr 05, 2007 1:34 pm
quote]you need some of these....
[/quote]
Does anyone know where to get them from in Sydney? They seem to work well on rjastra's PoLo but my other mates PoLo and Golf not so well.
Juffa
Postby Juffa » Thu Apr 05, 2007 2:14 pm
Over the years I have tried various inserts and have noted the following. What has worked the best for me is not so much to do with the blades but ensuring that the windscreen is given a very good clean on a regular basis. I have used a paste based product that would remove built up grunge from the glass. It is a bit like using a clay bar on your paint. All the small ridges are removed and the wipers are able to do a better job. I ran out of the paste and have not actually gotten around to buying some more...must add that to the list.
Ps don't use a harsh cleaner, such as ajax or jiff to do this . They will sratch the glass...you might not notice it at the time, but you certainly will when driving in bright sunlight.
J
green_comet
Car Detailing Guru
Postby green_comet » Thu Apr 05, 2007 2:33 pm
Anyone know of a place here in Melb, where you can get those Trico Neoform Beam Blades?? Been doing some reading and they seem quite good..
meanmx
Postby meanmx » Thu Apr 05, 2007 5:29 pm
You can also clay bar your windows and it does the same thing as it does for the paint. Removes all the crap to allow for a smoother wipe.
Ben
2014 VW Mk7 Golf R
Alex
Postby Alex » Thu Apr 05, 2007 9:33 pm
normally a quick wipe of the blades every now and then will make them work like new again
I found a layer of oxidised/sun damaged rubber on mine is normally the culprit when they don't work properly, quick wipe over and all the black crud comes off and good as new :D
