I just bought a NA hardtop for my NB. Found the heater/demister connector doesn't fit. Anyone know where to get an adapter?
(already tried Mania).
Hardtop Demister
- Peter Howe
Hardtop Demister
Pete - Red SP
Mania RB2 stylebar, 3M Film, quick shift stick, Tein SS, Torsen, hardtop, Mania ECU.
- Craig
- Vehicle: Non MX-5
Peter,
Mate seriously you're never going to use it anyway, I never have in the 7 years I've used hard tops. Just keep the rear window clean and use the air con for a few minutes to clean up any misting that may appear.
Better yet drive topless!
Craig
Craig
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds! ***
- Alex
you should be able to find some on one of the various mx-5 sites
if you really need one then ask mania when they will be getting their next NB wreck in and ask if you can have the demister plug from the soft-top then just put it on your hardtop
and aircon doesn't always work for example if you park your car outside overnight when it's cold and foggy like it has been the last few mornings, it takes a while for the engine to warm up to get enough heat out of the air vents to heat up the cold window and stop moisture condensing on the outside so you do need a demister
but then most of the time it's just a matter of too much moisture in the air inside the car so the aircon works
- Peter Howe
Craig wrote:Peter,
Craig
The only reason I bought it is that I'm travelling to Melb quite a lot (next motorway is the Eastlink project), and a couple of months ago, got my softtop slashed at the airport. Now having replaced it, I'm not willing to chance it again for the insurance excess and likely bad history.
Pete - Red SP
- Garry
I found the A/C to be much more efficient at demisting the rear window than the electric demister, unless the misting is on the outside. So like Craig, I very rarely even bother to plug it in when I fit the hardtop.
As for getting the right plug, try Mazda or Mania or have a look at the vendors on Miatanet. Not many other options around really
- Benny
I'm with Craig on this.
I have never bothered to plug in the demister in the 8 years I've had a hardtop.
For one thing, it's really fiddly to do, and I've never needed it.
I'm also worried that when removing the hardtop, I might forget to unclip the plug and rip it out.
I've never even plugged in the plug for the soft top either.
Wise idea to get a hard top though Peter.
Especially as this is your everyday car.
- Fuzzlet
Users browsing this forum: No registered users and 173 guests
