Retractable Power Antenna
RaYmO
Postby RaYmO » Sun Feb 25, 2007 3:09 pm
Hi Guys,
Just wondering if any of you have replaced the stock Antenna on the NA for a power retractable one (kinda sick of the flagpole being up all the time).
Can a forumite please point me in the right direction?
Ray
STV
Postby STV » Sun Feb 25, 2007 3:32 pm
just chop the stock one down from being 3ft long to being 1 ft long. i have no loss of signal and it looks loads better.
no cost = nothing to lose!
especially if you intend to get rid of it anyway
stv
Where is 'Home Sweet Home'?
Babalouie
godfather of saké
Postby Babalouie » Sun Feb 25, 2007 3:32 pm
NA8s have retractable antenna...can it be retrofitted?
Babalouie
godfather of saké
Postby Babalouie » Sun Feb 25, 2007 3:33 pm
Also could you fit one of those stubby S2000 antennas?
AJ
Postby AJ » Sun Feb 25, 2007 3:35 pm
or one of the NC ones.......a lot shorter & look the part :)
XMX5 Rogues
STV
Postby STV » Sun Feb 25, 2007 4:31 pm
can get the stubby S2K ones from ummmm... metromotorsports.. link below
http://www.metromotorsports.com/product ... prodID=539
$20US isnt too bad i guess... Group Buy to save on postage??
STV
Fatty
Postby Fatty » Sun Feb 25, 2007 5:21 pm
cutting it down sounds intersesting stv. did you just cut it at the top, or at the bottom and then feed it down thru the hole? photos ? i'm just having trouble picturing it in my head.
also, jaycar have a black rubbery one with a spring on it similar to the s2000 one, but it doesn't look as nice i think. i would be interested in a group buy on the s2000 one, if the cut down method doesn't look too nice.
Old EmmGee
Postby Old EmmGee » Sun Feb 25, 2007 5:30 pm
I tried a stubby alternative for a while - loss of reception ensued so went back to the old 'stingtail'. I reckon if you are going to cut it down, you should remove a section from the :lol: middle....
MX5-less; need another!
Fatty
Postby Fatty » Sun Feb 25, 2007 5:31 pm
a section from the middle?
tell me how to stick the two remaining sections together and i'm there! :D
STV
Postby STV » Sun Feb 25, 2007 6:53 pm
Fatty, i took a very scientific approach to doing this.
1) I guestimated roughly where i wanted the top of the antenna to be and marked it with a marker
2) i unscrewed the antenna from the vehicle in question
3) i attacked the son-of-a-bitch with a hacksaw
4) broke a blade in the process (its seriously HARD steel!)
5) stuck on a bling valve nut with some paste/weld stuff
6) screwed the shorter version into place!
i also gave it a quick polish with some brasso while it was off (i was stuck at work waiting for my new job to start!)
http://img133.imageshack.us/img133/6016 ... 839bb1.jpg
http://img451.imageshack.us/img451/4983 ... 392ie4.jpg
RaYmO
Postby RaYmO » Sun Feb 25, 2007 8:08 pm
Ive got one of those rubbery stubby antennae lying around, but I really am after something powered so that the entire antenna is hidden from view when Im not in the car... just makes the exterior cleaner IMO.
Retrofitting a power antenna from a NA8 sounds like a plan... Might check Miata.net to see if there is a guide there.
Moggy
Postby Moggy » Sun Feb 25, 2007 8:27 pm
Also up for a group buy if anyone finds a good alternative.
I'm sick of people asking if my car is radio-controlled... :? :| :P
SuperMazdaKart
Postby SuperMazdaKart » Sun Feb 25, 2007 9:17 pm
mine is 8)
uses a Wii controller
Wuey
Postby Wuey » Tue Feb 27, 2007 1:36 pm
Personally I wouldn't bother with a powered antenna based on my past experience with them. With a bigger diameter they attract dirt faster. OK, you can clean and lubricate it regularly but the grits will get into the gaps causing problems. Sooner than later, it will get to a stage when it will not extend or retract fully. More headaches for what it's worth. Besides, I don't mind the RC look of the stock antenna.
Image 2004 SE
JSE
Postby JSE » Tue Feb 27, 2007 2:30 pm
reading this thread got me off this computer chair and out in to the garage just now. I just hacked my atenna down to a much shorter size and painted it black. WIll see if it still holds a good signal soon when the paint dries.
