Boost Gauge Into Air Vent
Posted: Fri Feb 02, 2007 2:26 pm
by JSE
Hi - calling all turbo owners,
Which size boost gauge fits into the air vents on an NA. 52mm (2 1/16\") or 66mm ( 2 5/8\") ? I have heard that both fit...the 52mm you don't take off the outer ring/trim of the vent and the 66mm you do take off the outer trim. Can someone comfirm this or shed some insight into this for me please. I know there was a post just recently about this in NBs but all the posts in that thread didn't really answer this question.
Thanks
Joel
Re: Boost Gauge Into Air Vent
Posted: Fri Feb 02, 2007 5:50 pm
by blackster
JSE wrote:Hi - calling all turbo owners,
Which size boost gauge fits into the air vents on an NA. 52mm (2 1/16") or 66mm ( 2 5/8") ? I have heard that both fit...the 52mm you don't take off the outer ring/trim of the vent and the 66mm you do take off the outer trim. Can someone comfirm this or shed some insight into this for me please. I know there was a post just recently about this in NBs but all the posts in that thread didn't really answer this question.
Thanks
Joel
Im using a 2 1/16' autometer gauge and hence utilising outer ring and airvent ball cage, nice n sluggly fit no rattles.
Posted: Fri Feb 02, 2007 7:35 pm
by Duj
Get a razor blade and slice a bit of the inner soft plastic off,
a 2.5/8 Autometer boost guage will slide in there nicely and hold itself in 8)
Posted: Sat Feb 03, 2007 4:15 pm
by 4sfed5
yeah im using a 2 5/8\" and it required just the slightest bit of cutting away the inner plastic inside the dash bit to get it to fit..Not a big job and wont effect the original vent going back in either
Posted: Sat Feb 03, 2007 4:24 pm
by JSE
THanks for information guys. Just bought an Autometer Z-Series one today 2 1/16. Cheers for help
