Hi - calling all turbo owners,
Which size boost gauge fits into the air vents on an NA. 52mm (2 1/16\") or 66mm ( 2 5/8\") ? I have heard that both fit...the 52mm you don't take off the outer ring/trim of the vent and the 66mm you do take off the outer trim. Can someone comfirm this or shed some insight into this for me please. I know there was a post just recently about this in NBs but all the posts in that thread didn't really answer this question.
Thanks
Joel
Boost Gauge Into Air Vent
- JSE
- blackster
Re: Boost Gauge Into Air Vent
JSE wrote:Hi - calling all turbo owners,
Which size boost gauge fits into the air vents on an NA. 52mm (2 1/16") or 66mm ( 2 5/8") ? I have heard that both fit...the 52mm you don't take off the outer ring/trim of the vent and the 66mm you do take off the outer trim. Can someone comfirm this or shed some insight into this for me please. I know there was a post just recently about this in NBs but all the posts in that thread didn't really answer this question.
Thanks
Joel
Im using a 2 1/16' autometer gauge and hence utilising outer ring and airvent ball cage, nice n sluggly fit no rattles.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Vehicle: NA6 - Turbo
yeah im using a 2 5/8\" and it required just the slightest bit of cutting away the inner plastic inside the dash bit to get it to fit..Not a big job and wont effect the original vent going back in either
