Shaving Taillights?
GP
Shaving Taillights?
Postby GP » Wed Dec 20, 2006 1:16 pm
I read in a recent post \"Shaving Tailights\" was mentioned. I maybe mis reading but is this refering to getting rid of the ugly writing that's on all the lenses? If so anyone got tips :D
Graham
Astroboysoup
Postby Astroboysoup » Wed Dec 20, 2006 1:19 pm
I gave it a go ages ago on the reflector lenses. Thought id try on them first to see how good i can get it.
Wasn't too bad but I just couldn't get the plastic to polish up afterwards to be as nice as it once was.
Seemed a little darker and hazier but still worked
MasterZ
Postby MasterZ » Wed Dec 20, 2006 1:28 pm
1992 Mazda MX5 Turbo | 2004 VW Golf GTI | 2010.5 VW R36 Passat Wagon | 1985 Mazda HBES 929 13b Turbo | 1987 Mazda RX7 FC3S Turbo | KE20 Corolla Coupe
kula
Postby kula » Wed Dec 20, 2006 3:03 pm
or you can follow my article here:
http://www.motoractive.com.au/article11.htm
PT
Postby PT » Wed Dec 20, 2006 3:33 pm
It was me who mentioned it GP.
I've done it to all my cars... And they are now shinier and cleaner than before.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
GP
Postby GP » Wed Dec 20, 2006 4:01 pm
Thanks heaps guys, I will have a go at a couple of smaller lenses tonight. :D
On the subject, Does anyone know how the little round indicators come off?
Graham
Wuey
Postby Wuey » Wed Dec 20, 2006 4:02 pm
I did mine since Moses parted the Red Sea. I suggest start off with 400 followed by 800 and 1200 or if you're fussy, 2000 grade sandpaper. To give the lenses a brilliant gloss, use Meguaires plastic cleaner and polish. The result will be better than new. If you don't have the Meguaires stuff, I think regular paint polish and wax would do the job.
Image 2004 SE
Techno
Postby Techno » Wed Dec 20, 2006 8:12 pm
Best results come from using a stiched rag polishing wheel. Use the lightest cut soap (white) and be careful not to overgeat.
This will get far better results than wet paper.
Woo
Vehicle: 10AE - Turbo
Postby Woo » Wed Dec 20, 2006 8:48 pm
Technos on the right track, but it is easy to melt the soft plastic.
IMHO the word is \"Silvo\" (Yes, the silver polish you use on the Chrissy cutlery)
A bit on a soft cloth following the fine wet n dry, rub like all hell and the scratches will slowly but surely disappear.
Works a treat :idea:
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
PT
Postby PT » Thu Dec 21, 2006 8:41 am
GP wrote:Thanks heaps guys, I will have a go at a couple of smaller lenses tonight. :D
From memory they pop off, so lever your fingers underneath it and pop it off.
Past:
2005 Mazda MX-5 SE
1991 Mazda MX-5 NA6
Andy Wana
Postby Andy Wana » Thu Dec 21, 2006 9:07 am
You can also use a piece of towel and a slotted screwdriver to pop it off
Put the towel against the car's bodywork and use the screwdriver as leverage
Whichever way you choose, both methods work
I ♥ asymmetry
Postby Okibi » Thu Dec 28, 2006 7:26 am
I did it to mine awhile ago, it's not too hard to polish up afterwards if you don't scratch them to buggery with sandpaper.
I was doing them at work so just used some ajax from the cleaners cupboard, it had enough fine grit to polish them up well.
