MasterZ
- Vehicle: NA6 - Turbo
Postby MasterZ » Mon Dec 18, 2006 10:07 pm
hey everyone, im most likely going to drive up to mania with my dad and gf. my dad's gonna ride his vmax while i drive the mx.
the reason im going up there is to purchase the rear deck cover that they have:
http://www.mx5mania.com.au/product618.htmhas anyone got one from mania and they have eBay style bars installed?
i hope that makes sense
1992 Mazda MX5 Turbo | 2004 VW Golf GTI | 2010.5 VW R36 Passat Wagon | 1985 Mazda HBES 929 13b Turbo | 1987 Mazda RX7 FC3S Turbo | KE20 Corolla Coupe
coolabah2002
Postby coolabah2002 » Mon Dec 18, 2006 11:08 pm
great idea!!
but, you should always ring first whether they have that stock in hand.
they are the busy lot, and the stuffs that they are selling often are out of stock.
MasterZ
Postby MasterZ » Mon Dec 18, 2006 11:10 pm
thanks for the advice ;)
Boags
Postby Boags » Tue Dec 19, 2006 10:17 am
Definately find out if it is in stock! It could be another front lip spoiler fiasco!
99MXV
Postby 99MXV » Tue Dec 19, 2006 11:31 am
Boags'MX5 wrote:Definately find out if it is in stock! It could be another front lip spoiler fiasco!
*waves at Boags*
Won't be long now... On the hunt for an MX5
MasterZ
Postby MasterZ » Tue Dec 19, 2006 2:09 pm
why what happened with the front spoilers?
Craig
- Vehicle: Non MX-5
Postby Craig » Tue Dec 19, 2006 6:15 pm
I avoid Mania as much as possible...because I always get tempted to buy something!
MasterZ
Postby MasterZ » Tue Dec 19, 2006 6:42 pm
i asked them if they have the rear deck covers in stock but they don't
i guess ill wait
JSE
Postby JSE » Tue Dec 19, 2006 7:35 pm
Mania are closed thursdays arn't they?
rodent
- 강남 스타일
Postby rodent » Wed Dec 20, 2006 1:53 am
Thursdays are by appointment only, so if you've double-checked and triple-checked with them that Daniel will be in that day then you should be fine
MasterZ
Postby MasterZ » Wed Dec 20, 2006 9:18 am
paddy wrote:How did you go with the rear deck from mania?
they had none in stock when i emailed them
Gramps
Postby Gramps » Wed Dec 20, 2006 11:53 am
rodent wrote:Thursdays are by appointment only, so if you've double-checked and triple-checked with them that Daniel will be in that day then you should be fine
David is working there full time now but you definitely need to double check whether anyone is working Thursdays.
Wouldn't anyone make an appointment first - not just turn up and expect to get work done - they are very busy after all.
"When you're racing against Father Time drive a 5!"
MasterZ
Postby MasterZ » Wed Dec 20, 2006 1:05 pm
Gramps wrote:rodent wrote:Thursdays are by appointment only, so if you've double-checked and triple-checked with them that Daniel will be in that day then you should be fine
do you need to check if anyone is working there just to buy a part and leave and not have it fitted by them on a Thursday?
Craig
- Vehicle: Non MX-5
Postby Craig » Wed Dec 20, 2006 1:09 pm
MasterZ wrote:Gramps wrote:rodent wrote:Thursdays are by appointment only, so if you've double-checked and triple-checked with them that Daniel will be in that day then you should be fine
Always happy to sell you stuff, but more the fitting/servicing that needs booking in.
Boags
Postby Boags » Wed Dec 20, 2006 1:19 pm
I think the shop is shut - as in the door is closed and noone is there to take your oney
- on Thursdays unless there is an appointment. Correct me if i'm wrong though.
