Posted: Tue Dec 12, 2006 10:47 am
by GP
Me too :D The passenger window is painfully slow
Posted: Tue Dec 12, 2006 11:27 am
by bigdog
As you can see below, Garry is the expert on window lube Monsqueek... at least I think he was using it on his windows... :shock: :P AFIK he simply removed the door trims and sprayed lube on the moving parts. Maybe he can clarify for you?
Posted: Tue Dec 12, 2006 11:30 am
by StanTheMan
take the tracks out.
I cleaned very thoroughly with turps.
then lubricated them with stuff similar to what Garry is showing.
Its lasted more than 6mths so far.
Posted: Thu Dec 14, 2006 2:14 pm
by sabretooth
It sounds like the state that invented dodgy days... needs one!
That's the stuff to use alright. You can get away without taking the tracks out if you don't clean them and instead spray the grease in. It's preferable to clean them though.
You don't have to remove the cabling or anything like that - you'd just be pulling the tracks from the door. If you're familiar with it it's straightforward but if not it's best to leave it and get someone to get their bum into gear and organise a dodgy day.
Posted: Thu Dec 14, 2006 2:49 pm
by Andrew
sabretooth wrote:It sounds like the state that invented dodgy days... needs one!
Sounds like a good idea :mrgreen:
Need to install my fog lights, paint my valve cover and reinstall with chrome dome bolts and do some work on my brakes, apart from that all is good.
Posted: Thu Dec 14, 2006 6:25 pm
by Blue94t
I am in for a dodgy day.
I have a few things to do, lube passenger side window runners, timing belt, and water pump. I think that just about covers it.
I have a pretty well equiped workshop and am prepared to host depending on numbers. Don't have that much space if there are too many people.
I also have the factory workshop manual for NA MX5's.
Jake
Posted: Thu Dec 14, 2006 6:36 pm
by green_comet
Im getting my brown davis bar in a week or soo... sounds like a good excuse to goto dodgy day.. :mrgreen:
Posted: Thu Dec 14, 2006 6:42 pm
by Andrew
Could be good.....now to set a date :?:
Posted: Thu Dec 14, 2006 9:51 pm
by Andrew
No real christmas obligations here either....up until 26th 8)
Posted: Fri Dec 15, 2006 3:05 pm
by Blue94t
MonSqueek wrote:excellent, well I suppose its up to the host !
Well I guess that would be me since there do not appear to be any other offers.
7/1/07 would be the first weekend I am available as I am in Qld over New Years.
I have pretty much any hand tools you could need.
Pretty good supply of power/air tools as well.
Got a couple of hydraulic jacks and a couple of sets of axle stands.
I also have an engine crane if anyone needs to take on something that serious.
I am lacking in drill bits as my good set got stolen so if any drilling needs to be done (roll bar fitments, etc) I suggest you bring the size you need.
If you can bring the tools for the job you want to do it will make life easier, happy to supply tools if you can't.
If you want to do any servicing you must take waste oils/fluids with you.
I am more than happy to assist with any jobs on the day but will be reasonably busy with the timing belt/water pump on my car. Once that is done I can assist with anything, and I mean anything ;)
I normally choose to avoid the crappy, dirty jobs.
I will be visiting my parts supplier next week so if anyone needs any bits let me know, I normally get pretty good prices.
Importantly I also have a bbq. If people want to byo meat I can prob organise a salad and some bread or something.
Let me know who is keen so I can get an idea on numbers.
Jake
Posted: Sun Dec 17, 2006 5:18 pm
by Insurgence
Registering my interest for a dodgy dayyyyy!
wohoo I always envied the dodgy days of other states! :mrgreen:
- I can bring my own hand tools & drill bits if people need them
- BBQ sounds good :)
Posted: Fri Dec 22, 2006 10:28 am
by Blue94t
Sorry about the delay in replying.
I will post something in events over the next couple of days. Been flat out.
What sort of brake pads do you want?
good stuff or just standard?
Jake
Posted: Sat Dec 23, 2006 9:17 am
by mr_rotary
MonSqueek wrote:
StanTheMan wrote:take the tracks out..
Wooohhha ! Hold up the horses, that involves tools ! I dont have a licence to weild any tool, and if the tracks need to come out doesnt that involve unhooking the cables? Which sabertooth and I can both attest to the fact they are complicated little puppies to wind back on?!!?
And what is that stuff and where do I get it?
The main track comes out in one piece and is not as hard as it appears. Off memory, dissassemble as follows:
* Take off door handles (2 x phillips screws underneath) and take off door latch trim.
* Unclip Door trim off but be very carefull you don't pull the plastic clips out of the door trim!
* Wind window half way up and you wil see at the base of the window through an opening in the door a clip that holds the window in place with screws. Undo the screws and pull window frame out from the top.
* The main window rail unbolts from underneath the door (2 x screws). I can not remember if there any other screws.
At this point you could just leave the rail in and just spray the rails with them still inside the door. Give yourself about 1 1/2 hours tops to do all this for a first timer.
Hope this helps 8)
Posted: Sat Dec 30, 2006 2:23 pm
by Insurgence
mr_rotary wrote:Instructions
So that's how you do it properly! :shock:
I just kinda sprayed stuff into the rails.
Also: I have some ramps suitable for mx5 which i could bring.
