Droopy Eyes
GP
Droopy Eyes
Postby GP » Fri Dec 01, 2006 1:31 pm
Hi All
Saw this pic in another thread and my car has the same problem. Is there a procedure to raise them up to the bonnet level?
Graham
davamb
Postby davamb » Fri Dec 01, 2006 1:43 pm
Yep, sure is GP,
Raise the lights using the centre console switch.
Remove the black plastic surround from the lights.
You will now find 4 philips-head screws that attach the light cover to the rest of the light structure.
Loosen these just enough so's you can move the cover up and down.
Now lower the lights and use a suitable tool to adjust the heights. I used a piece of coathanger wire that I'd bent the end over to make a 5mm lip, but you could use just about anything that comes to hand.
When satisfied, raise the lamps, tighten the screws and replace the plastic covers.
I had a bit of trouble with mine as some moron had had a go at it in the past and damaged 2 of the screws (grr!). I had to use an angle grinder to take the heads off the screws and then replace them. I used stainless M5 allen-headed socket screws to replace the old ones.
Cheers, Dave, 1990 NA6
Via est vita.
Philip Lee
Postby Philip Lee » Fri Dec 01, 2006 1:43 pm
the easy method - just pull the bugger upwards but it might damage something so do it at your own risk.
the proper method - unscrew 4 screws on each side of the black plastic cover and 4 screws that hold the cover will be exposed. undo them, adjust, redo them and all done.
easy.
Andy Wana
Re: Droopy Eyes
Postby Andy Wana » Fri Dec 01, 2006 2:20 pm
GP wrote:Hi All
My car is not a problem car :cry:
Anyway, I'll get those droopy eyes fixed into bedroom eyes soon :D
Been wondering whether there's anything I can do to make the lights align
I ♥ asymmetry
Astroboysoup
Postby Astroboysoup » Fri Dec 01, 2006 2:43 pm
yeh jsut gently pull them up...
pop the bonnet and pull.. its fine just take care... gentle... did it with mine
GP
Postby GP » Fri Dec 01, 2006 2:46 pm
Wow, You guys are great with the answers I need. Thankyou very much.
Andy. Sorry mate, your car is sweet and a great colour :D
Graham
jules
Guitar Hero
Postby jules » Mon Dec 04, 2006 11:10 am
Just pop the bonnet and gently pull them back up. They will go down again with time, depending on how often and how vigorously you wash your bonnet.
Jules
JBT
Postby JBT » Mon Dec 04, 2006 11:15 am
jules wrote:They will go down again with time, depending on how often and how vigorously you wash your bonnet.
.......and how often people lean on them when the bonnet is open :roll:
