1992 na6 headlight replacement - australian delivered
devolutio
Postby devolutio » Sat Oct 28, 2006 12:19 pm
hey, before i get flamed I did search around for the answer to this but couldn't get any definate answers, and I haven't had a chance to actually look under the bonnet but need to replace a non working headlight tonight.
so it's 1992, australian delivered mx5. do i have sealed beams or can i just replace the globes? if it's a sealed beam, where can I get them from?
thanks for the help
clayton
Babalouie
godfather of saké
Postby Babalouie » Sat Oct 28, 2006 12:37 pm
You can just replace the globes....
Pop up the lights on the retractor switch, then undo the 4 screws on the side and remove the black plastic shielding. There are 3 screws holding the headlamp onto the pop up mechanism, undo those and the headlamp falls out. It's then a fairly straighfwd business of unplugging it at the back, and then unclipping the globe and putting in a new one.
Just go to your local parts shoppe and ask for a std H4 globe.
devolutio
Postby devolutio » Sat Oct 28, 2006 2:42 pm
perfect answer! were there any that had sealed beams?
thanks for the assistance.
Juffa
Postby Juffa » Sat Oct 28, 2006 2:56 pm
As an Aussie delivered 5 it should not have sealed head lights. If it does turn out to have sealed beams I would suggest that you head down to your local auto parts store and get some Hella H4 headlights. You can buy it as a kit containing two headlights, with bulbs. This way you get better quality of headlight and the ability to just change the bulbs down the line.
Just my 2c worth
J
kitkat
Postby kitkat » Sat Oct 28, 2006 4:41 pm
devolutio wrote:perfect answer! were there any that had sealed beams?
imports have em.. well mine does anyway... $10 (maybe $15) each,cost no more than globes and just as easy to replace. Give off pretty good light aswell.
devolutio
Postby devolutio » Sat Oct 28, 2006 6:56 pm
information was correct - thanks. bought some h4 bulbs for around $17 each and installed them.
just realised how damn filthy the headlights were - so i used some jif on a rag to clean them up... looks fantastic. try it.
thanks again.
