Setting off down the path of Bling!
Gazbo
Postby Gazbo » Mon Oct 23, 2006 7:55 pm
OK, I'm trying to keep it subtle, tasteful even.
I now have a Voodoo gear knob & handbrake lever, with SCALA leather boot/gaiter.
Rather than go for chrome, I've decided that the polished or satin look is more subtle.
Next I'm thinking of \"satin\" vent rings. Wouldn't mind a Nardi Classico wheel too...
Could anyone post a photo of these in an NA ?
Also thinking of getting the missing three gauge rings for the instruments. Are they as hard to fit I'm led to believe?
This could get addictive...
rodent
강남 스타일
Postby rodent » Mon Oct 23, 2006 9:19 pm
Looks great Gazbo! :D
Do you ever get the ouchies after your car has been parked in the hot sun for a while though? My black Voodoo knob does that a little on some days. :(
Justin Fox had a Nardi in his NA - the new owner has posted pics here
Gazbo
Postby Gazbo » Mon Oct 23, 2006 10:45 pm
I usually leave my cap over the gear knob when parked, so far heat not a problem - but it's early days yet...
That Nardi wheel looks great, are they the same diameter as the standard wheel, I wonder?
I've dríven an MX-5 with a smaller Momo wheel and just couldn't see the instruments properly. The larger diameter seems more \"vintage\" anyway.
Uncle Arthur
Dodgy Award Benefactor
Re: Setting off down the path of Bling!
Postby Uncle Arthur » Mon Oct 23, 2006 11:25 pm
Gazbo wrote:OK, I'm trying to keep it subtle, tasteful even.
Bling is not subtle - just ask Ryan.
:D
Or me :D
Or even Wayne - he put bling on the Whirlpool. Or is it the Dishlex??? I can never remember..... :mrgreen:
Gazbo
Postby Gazbo » Tue Oct 24, 2006 11:04 am
You trying to tell me that subtle bling is an oxymoron? :D
Philip Lee
Postby Philip Lee » Tue Oct 24, 2006 11:34 am
Justin's Nardi is 330mm and the stock Momo is 360mm. Nardi produces a 360mm for the same style too.
i had the same Nardi but as u said i can't see the dials too so i have since replaced with a 350mm Momo. it's smaller which gives me more space and i can still see the dials so the best of both worlds.
jules
Guitar Hero
Postby jules » Tue Oct 24, 2006 12:01 pm
Gazbo. You are doing EXACTLY what I have done. I'll look for some pics. The gauge cluster rings are a MUST have IMHO.
BTW, get a chrome button for the handbrake handle. There's a genuine Mazda part for the Titanium MX-5. They just screw on and complete the look.
Pics to come!
Jules
jules
Guitar Hero
Postby jules » Tue Oct 24, 2006 12:08 pm
This is the only one I seem to be able to find. It doesn't really show the cluster rings, but you get a good idea about the chrome button on the hand brake.
Jules
jules
Guitar Hero
Postby jules » Tue Oct 24, 2006 12:11 pm
Oh, and the rings were \"fairly\" easy to fit. I went very slow and steady and used Araldite. DO NOT USE SUPERGLUE. It will cloud the clear plastic.
They have been on for 4 years without drama.
Here's another pic
Jules
Boags
Postby Boags » Tue Oct 24, 2006 6:12 pm
jules wrote:Image
How do you keep your skin looking so youthful? :shock:
jules
Guitar Hero
Postby jules » Tue Oct 24, 2006 6:28 pm
BANGING YOU!
Jules
Boags
Postby Boags » Tue Oct 24, 2006 6:33 pm
jules wrote:BANGING YOU!
Jules
:oops:
You told me you were taking my temperature...
Gazbo
Postby Gazbo » Tue Oct 24, 2006 6:41 pm
Jules, thanks for that photo, I wasn't going to get the instrument rings, but after seeing yours, I'll be ordering some.
A question about your leather handbrake boot, did you pull the boot all the way down to the rubber o-ring?
Mine has about 1cm overlap where the leather is doubled over, if you know what I mean?
Not sure if I've installed it correctly?
jules
Guitar Hero
Postby jules » Wed Oct 25, 2006 11:10 am
Mine is the same as yours.
There's a 1cm overlap where the boot goes over the O ring and under itself. You basically turn it inside out to fit with the ring 1cm from the end and then pull the whole boot down onto the handbrake.
I then jammed the O ring into the small gap between the Voodoo grip and the old plastic handbrake cover.
Just a tip in regards to the Benny's gear stick boot. If you leave the old one still attached and just put the new one on top of it, you get a really nice thick feel, and the gap between boot and Voodoo is closed up perfectly.
I hope this makes sense.
Jules
jules
Guitar Hero
Postby jules » Wed Oct 25, 2006 11:15 am
Boags'MX5 wrote:[
I was....
Jules
