NB RADIO INTO 90 NA
micksta
NB RADIO INTO 90 NA
Postby micksta » Sun Oct 22, 2006 12:10 am
HI ALL
JUST CHECKING MY INFO IS CORRECT
I WANT TO FIT AN NB FACTORY RADIO/CD INTO MY 90 NA
I NEED TO BUY A 97 FASCIA AND IN SHOULD FIT IN WITHOUT MODIFYING IT.
MANIA SELL THEM, IS THERE ANYWHERE IN MELB
THANKS IN ADVANCE
MICKSTA
90 ltd edition
rodent
강남 스타일
Postby rodent » Sun Oct 22, 2006 12:24 am
Wahey micksta,
Yes you will need the '97 fascia as it is has proper double-DIN spacing and the edges inset properly so the NB deck mounts flush into it.
You should be able to get them from Mazda directly for about the same price, and if you do a search on these forums (and if it works :)) you'll find the exact part numbers mentioned somewhere as well.
jonno.
micksta
Postby micksta » Sun Oct 22, 2006 12:27 am
thanks jonno
micksta
90 ltd edition
