Noisy windows
Garry
Postby Garry » Wed Oct 18, 2006 9:32 am
Try pulling the door trim off and lubricating the window tracks inside the door
Garry
Postby Garry » Wed Oct 18, 2006 10:31 am
There are nylon rollers that are supposed to slide in metal tracks inside the door cavity. Maybe there is something lodged in the track or the rollers are seized or worn. I've heard the noise you are talking about in an NB8A. But in that car it only made the noise when it was hot. I never had a chance to investigate the cause of the problem though. The owner decided to buy a new car.
Postby Okibi » Thu Oct 19, 2006 2:20 am
I had my drivers side door skin off the other day so lubed the power window too.
The drivers side window was almost a second faster than the passanger side so I ended up doing them both. :lol:
idb000
Re: Noisy windows
Postby idb000 » Thu Oct 19, 2006 2:28 pm
Shaker wrote:The driver's window on my NB makes a nerve grating scraping noise as it is raised or retracted. Sounds like scraping a lump of rock across the glass. There are no visible scratch marks on the glass. Any one else had this problem.
Mine does this too occasionally. What do you use to lubricate the windows/tracks?
2001 Black MX5 NB8B
http://www.idb000.com
Postby Okibi » Thu Oct 19, 2006 2:51 pm
I don't know what is the correct item to use ...
I use teflon based mountain bike chain lubricant and Nulon \"Ezi-Glide\" clear silicon lube on the rubber bits. This stuff worked like magic on sliding doors and hinges too.
If you get a bottle with a thin plastic straw you can give the window \"tracks\" a little lube every now and then without taking the door skin off. Just wind down the window and gently pull the rubber back until you see the tops of the tracks.
Postby Okibi » Thu Oct 19, 2006 3:33 pm
To remove the door skins ...
Users browsing this forum: Google [Bot] and 4 guests
