Page 1 of 2
Re: Starter Buttons.
Posted: Sun Sep 24, 2006 1:37 pm
by fig
Daz 27 wrote:so who's got a starter button fitted in their car?
can you post a pic & let us know what type it is & where you got it from, thanks.
Calling Andrew
Posted: Sun Sep 24, 2006 1:50 pm
by Babalouie
I got the Zoom Eng one, which plugs into the switch blank next to the dashlight dimmer.
http://www.metromotorsports.com/product ... ProdID=119Great product, 2mins to install, been working fine for almost 4yrs now. I bought mine when I was in Japan tho.
Posted: Sun Sep 24, 2006 3:56 pm
by Matty
I DIY'd my hazard button into a BRB. But I got bored with it. The loom's in the garage...
Posted: Sun Sep 24, 2006 5:09 pm
by green_comet
I have an s2k starter button in mine..between the two gauges.
Posted: Sun Sep 24, 2006 6:51 pm
by Andrew
fig wrote:Calling Andrew
From here -
here
Posted: Tue Sep 26, 2006 12:07 pm
by vrmmmpshhh
i have a zoom one too. took few mins to install and blends in with the interior.
Posted: Tue Sep 26, 2006 5:11 pm
by green_comet
I got it when i was in USA earlier this year. I ordered it off of ebay for only $30us. I heard they are about $130+ here..
Here is the link to his ebay store, you could ask him if he will post the button here to Australia...
http://cgi.ebay.com/ebaymotors/JDM-00-05-Honda-S2000-engine-start-button-CIVIC-INTEGRA_W0QQcmdZViewItemQQcategoryZ33691QQihZ017QQitemZ270031702263QQrdZ1QQsspagenameZWDVW
Posted: Sat Feb 17, 2007 5:19 pm
by phaedo
Hi Green Comet,
How easy is it to install the starter button that you got? I have got myself a 94 clubman, so it should be the same setup... Also, would it slot into the cigarette hole? And is it illuminated?
Hamish
Posted: Sun Feb 18, 2007 9:47 am
by fredbareoz
We have the same starter fitted to our NA as Andrew's (Coutresy of Drew i might add, thanks mate) We had it installed where the cig lighter socket is.
Posted: Sun Feb 18, 2007 12:17 pm
by irwin83r
do these make it so the key no longer starts the motor or do they just kinda add a place that you can start the motor?...
like if you in stall one can you still start the motor with the key or do you HAVE to turn the key to on then push the button?
think id rather it need to be used if i installed it
Posted: Sun Feb 18, 2007 12:28 pm
by Andrew
Mine is configured that the key needs to be switched to on, the start button then illuminates you press it and the engine starts, and then the illumination goes off.
To turn the car off you just turn the key to off as per normal
(combine this with the ~30 second auto arm of the immobiliser and watching someone unfamiliar with the car try to start it is a good laugh
Posted: Sun Feb 18, 2007 3:52 pm
by green_comet
phaedo wrote:Hi Green Comet,
Hamish
It was pretty easy to do, there are heaps of guides on the net. I dont know if it will slot into the cigarette hole, but im sure it can be fitter there. The actual red button dosent light up, but the engine start writing lights up green, when your keys are in the on position, then turns out once the car is started.. its a pretty simple install, you should try it.
Sorry i took soo long to answer, I upgraded to Vista Ultimate, so was offline for a couple days.
Posted: Sun Feb 18, 2007 4:44 pm
by phaedo
Thankis for the replies guys, still tossing up which one to go for. Think the S2000 one will be a nicer button though, so will probably get that one.
Posted: Sun Feb 18, 2007 5:04 pm
by AJ
Posted: Sun Feb 18, 2007 9:14 pm
by Andrew
green_comet wrote:Sorry i took soo long to answer, I upgraded to Vista Ultimate, so was offline for a couple days.
WTF
I'm soooo glad i dont use MS operating systems
