paint wont stick, any ideas?
mio
Postby mio » Fri Sep 22, 2006 3:09 pm
Hello everyone,
i tried to respray my wheels today with a can of enamel gloss black paint, the paint won't stick, it sits on the surface and forms 'holes' where there is no paint. The surface is pre-painted already and in top condition (i just don't like bronze, i want black), I wiped it down before spraying.
Is there any way of getting the paint to stick without sanding the original paint off etc. ?
Benny
Postby Benny » Fri Sep 22, 2006 3:42 pm
You need to either go over them with a rag dipped in Prepsol (which removes any trace of oils) or give them a light sanding all over to make the paint stick.
If you're going to paint them black anyway, a good sanding would be the best preparation for them.
mio
Postby mio » Fri Sep 22, 2006 4:06 pm
thanks! i'll give it a try with the prepsol stuff first
mio
Postby mio » Sat Sep 23, 2006 3:41 am
I've tried Dulux QuitRust, which I believe would be similar to Wattyl's Killrust, it still ran...
OMY005
Postby OMY005 » Mon Sep 25, 2006 9:05 am
Silicone from the tyre shine stuff is causing your problem of the paint not sticking, forming holes is the giveaway.
You will need something like this to get it off.
Andrew. :)
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
