unopenable door?
SuperMazdaKart
unopenable door?
Postby SuperMazdaKart » Wed Sep 20, 2006 8:25 pm
my drivers side door won't open from the inside. the handle won't move outwards when i pull it, can still lock & unlock it manually & remotely (after market central locking). have had to lower the window & open the door with the outside handle which works still.
any ideas? i'm trying to get into contact with the installer of the central locking/immobiliser for him to have a look.
simple problem??
Fuzzlet
Postby Fuzzlet » Thu Sep 21, 2006 8:32 pm
Haha on my one sometimes the lock jams locked...i have to flick the outer door handle, then it unlocks :roll:
Postby Okibi » Fri Sep 22, 2006 12:40 am
There are rods that go from the handle (inside) to the catch that opens the door.
One of those must have popped out of its holder, if your lucky the holder hasn't snapped and you can just pop it back in.
SuperMazdaKart
Postby SuperMazdaKart » Sat Sep 23, 2006 3:49 pm
not to worry, got the trim off, nothing wrong inside from the looks of it & then it started working again......
well that was difficult
