NA Glove box adjustment for rattle?
Gazbo
Postby Gazbo » Sat Sep 16, 2006 7:06 pm
Help - my glovebox rattles, if I leave the glove box open the rattle stops.
Is there an adjustment on the latch - I can't find any?
Boags
Postby Boags » Sat Sep 16, 2006 7:35 pm
Count yourself lucky, i can't close mine at all. I ended up taking it out, cause you can't have open glovebox on your passengers lap all the time... :cry: I need to go to a dodgy day to fix it...
Back to the point, i don't think there is an adjustment for it... Maybe yours is breaking like mine did. :shock: hope not!
Boags
Mr_Q
Postby Mr_Q » Sat Sep 16, 2006 9:36 pm
I stuck some of that foam tape around the edges on my NA6 - that seemed to do the trick.
There's no adjustment, although you could check that the screws underneath are tight (probably won't fix the problem though).
Mister Q
Garry
Postby Garry » Sat Sep 16, 2006 9:44 pm
The latch wire is easy to bend. If you're lucky bending it may fix your problem. However if you bend it to far you might find the door is hard to shut. Just bend it back a little in the opposite direction.
Otherwise try Mr_Q's suggestions. Check to see that the screws on the latch and hinges are tight and add some foam. Though I found over time the foam would compress and it would start rattling again.
Gazbo
Postby Gazbo » Sun Sep 17, 2006 8:39 am
Thanks for the ideas, I've wrapped insulation tape around the wire latch, if that doesn't work will try the good old foam tape!
Adam_NAclubman
Postby Adam_NAclubman » Mon Oct 09, 2006 3:21 pm
Mine does exactly the same thing. I'll go have a play at fixing it today I think, it's been on my list for a while
RaYmO
Postby RaYmO » Mon Oct 09, 2006 3:45 pm
Adam_NAclubman wrote:Mine does exactly the same thing. I'll go have a play at fixing it today I think, it's been on my list for a while
I had the problem and just went to bunnings to get some rubber stops (about $3.50 for a packet of 15)
They are used to stop glass from smashing against hard surfaces (eg shower screens)
I just stuck them on the glove box, just where the surface of the glove box meets the factory rubber stopper. The glovebox still shuts fine and Ive managed to get rid of the squeak because it now closes firmly in place.
I may have a few more stoppers - Maybe I can put it up on the mx-5 parts for free page :D
Adam_NAclubman
Postby Adam_NAclubman » Mon Oct 09, 2006 4:33 pm
I went and started my car so I could listen for it and it didnt do it :(
I think it usually does it at night when the car has been sitting in the cold at work for 6 hours, then when I start it at 11:15pm I can really hear the glovebox buzzing, maybe it idles differently when its cold compared to now (seems like a nice 22 degrees atm)
RaYmO
Postby RaYmO » Mon Oct 09, 2006 5:17 pm
Adam_NAclubman wrote:I went and started my car so I could listen for it and it didnt do it :(
Yeah I did that for a while too but I had problems finding it... I think the car just knows that you are just waiting for the fault to happen so it just holds back...
The squeak only happens when Im driving along a road with a few bumps here and there... or on grooved roads...
After applying these plastic thingies the other day I havent heard one squeak so it must have worked :D
Adam_NAclubman
Postby Adam_NAclubman » Tue Oct 10, 2006 2:14 am
Mine only does it at idle when its coooold.
I did get rid of the rattly window today, greased all the rails. Just need to clean the switches now... Also padded out where the interior light switches in the doors contact the body so that the light doesnt flash when I hit a bumpy corner in the hills at night, thats damn annoying
FUN-29T
Postby FUN-29T » Wed Oct 11, 2006 12:10 am
I had a rattle around the instrument cluster hood and as i was tapping it ... and yes you've probably guessed ... IT BROKE !!! :(
I'm going to try and repair it and have it resprayed...
FUN-29T
Postby FUN-29T » Wed Oct 11, 2006 12:23 am
but at least i fixed one rattle... it's located behind the glovebox.. a metal bracket/seal for the air duct which was loose.. all it needed was new foam tape :P ... still disappointed about the instrument cluster hood though.. can't afford to replace it atm.. :(
FUN-29T
Postby FUN-29T » Wed Oct 11, 2006 12:48 am
i just found some helpful info...
http://www.miata.net/garage/noises.html
