problem with RAIN and my NC
Fatty
Postby Fatty » Wed Sep 13, 2006 7:29 pm
i used a toothpick on my NA6.
Mr_Q
Postby Mr_Q » Wed Sep 13, 2006 7:30 pm
The coat hanger is the best way - just wrap some tape or something around the end so it's not sharp.
I wouldn't have thought an NC would need cleaning out already - where are you parking? :shock: :)
Mister Q
Mazda Mandi
Postby Mazda Mandi » Wed Sep 13, 2006 8:28 pm
That's scary. Hope it doesn't happen to mine.
It's a thing of beauty!
Rocky
Concerned Citizen.
Postby Rocky » Wed Sep 13, 2006 8:37 pm
Like MrQ I'm wondering where you are parking as it usually takes a while for enough leaf-type fragments to build up & block the drain holes. Parking near trees with tiny leaves is best avoided as they end up in everything - air vents, doors, under bonnet. As suggested, coathanger/insulated wire is a suitable instrument for clearing drain holes.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Wed Sep 13, 2006 9:11 pm
You have to work out if it is the floor at the passenger side footwell or back behind the seat...if the drain holes for the soft top are blocked the water comes down behind the seat...if it is at the footwell it's probably the A/C drain pipe...assuming everything is the same on a NC as on a NA/NB...
Bevan
Postby Bevan » Thu Sep 14, 2006 11:50 am
Don't take it to service. They'll take note of water damage and probably void crap in the future. Best to do a DIY on the clearing out and leave the car in the sun for an hour with the roof off to dry it out.
