Help! Electric Window Dilemma !
JBT
Postby JBT » Mon Sep 04, 2006 8:12 pm
Probably a broken cable. Some info and photos here. Try a search on this website too.
Russellb
RIP Nov 2014
Postby Russellb » Mon Sep 04, 2006 8:19 pm
About the 5th one I heard of Breaking a cable in the last month
Replacment cables can be bought at mazda and are easy enough to install
You have to remove the whole motor and slider thingy then the old cables
can be rmoved and the new ones intalled in reverse order
My ClubmanRebuild
MX5 SE Rally car is HERE :)
99MXV
Postby 99MXV » Mon Sep 04, 2006 9:26 pm
DODGY DAY !
Won't be long now... On the hunt for an MX5
Mr_Q
Postby Mr_Q » Mon Sep 04, 2006 10:05 pm
Yep - very likely the cables. It's fairly common on the older cars. There are two on each side and they're around $40 - $45 each (from memory). As a bonus they'll make your windows work faster than they probably have for a long time. :D
The important thing is not to try using your windows until they're fixed. If you keep playing with the button you'll just tangle the broken cable more and possibly burn out the window motor. :(
Mister Q
