Ebay Style Bar Modifications
arnimaniacs
Postby arnimaniacs » Fri Aug 25, 2006 12:33 pm
After so many frustrated unsuccessful and failed attempts to fit the ebay style bar ($160AUD delivered) to my NA 93 model, I took it to a local welder and had it modified.
Originally the bar fits great without the extra rear bolts/nuts but the only problem was the passenger hoop was a bit too high, touching the soft-top and unable to latch the hardtop securely.
Here is the result, the bar is much lower than original and clear both soft and hard-tops without any problem.
Ma64rk on the forum has no problem with his NB hardtop so I guess its only the early model NA.
chrislevingston
Postby chrislevingston » Fri Aug 25, 2006 12:36 pm
Mine went on fine, with a couple of millimetres clearance for each.
arnimaniacs
Postby arnimaniacs » Fri Aug 25, 2006 12:40 pm
We bought another one for a 90 model and still the same problem. Its from the same ebay store.
Your super lucky then heheh
shelleriffic
Postby shelleriffic » Fri Aug 25, 2006 2:06 pm
Are those checkerplate rubber mats in your car?? If so, where did you get them from to fit the narrow width of an MX5?
Vroommm.
arnimaniacs
Postby arnimaniacs » Fri Aug 25, 2006 5:18 pm
I bought a set of 4 for $44 from a weekend market here in sydney. Just standard size. Its one of those spider floor mat.
adfox
Postby adfox » Sat Aug 26, 2006 5:40 pm
Ours fits our 89 no worries. The quality control on these things is terrible, you just got a bad one.
shelleriffic
Postby shelleriffic » Sat Aug 26, 2006 7:44 pm
arnimaniacs wrote:I bought a set of 4 for $44 from a weekend market here in sydney. Just standard size. Its one of those spider floor mat.
Oh I see. Damn. A friend had a set from Supercheat Auto ages ago but they were too wide for my car :?
Vroommm.
Users browsing this forum: No registered users and 169 guests
