Andrew.
NMX516 wrote:Am I correct in thinking that the karcher is drawing water from the watering can?
KAM wrote:I have been meaning to call the Brisbane Council to determine if this is acceptable as I had read on another forum it was ok in NSW.
Have you checked this with the Brisbane Council.
Brad wrote:One variation to this is to leave the bucket under a running tap and put the hose from the kartcher into that...though I don't condone this it's apparently still legal.
rhysk wrote:I have a bucket with a hose connector at the bottom, which solves the pump priming problem. And then keep the bucket under a running tap.
Brad wrote:Instead they are rigging up a greywater re-use system that collects the water from the washing machine for pumping to a hose cock at the back of the house for watering.
