Headlight panel gap - have you ever noticed...?
desertfox
Postby desertfox » Mon Jul 24, 2006 9:50 pm
Has anyone ever noticed that the panel gap between the driver's side headlight panel and the bonnet is slightly larger than the same panel gap on the passenger's side in some NA MX5's? This is when the headlights are in the closed position. Has anyone tried to fix it, short of taking it to a panel beater? I tried to pull the driver's side headlight panel to close the gap a bit but it's still not the same as the passenger's side. :?
Babalouie
godfather of saké
Postby Babalouie » Mon Jul 24, 2006 10:02 pm
The headlight lid is pretty malleable, so you can just kinda bend it slightly to get the fit that you want :)
desertfox
Postby desertfox » Mon Jul 24, 2006 10:06 pm
Babalouie wrote:The headlight lid is pretty malleable, so you can just kinda bend it slightly to get the fit that you want :)
I was concerned that the panel might come off. I don't know me own strength sometimes. :)
Babalouie
godfather of saké
Postby Babalouie » Mon Jul 24, 2006 10:07 pm
Well, don't use ALL Of your strength then :D
desertfox
Postby desertfox » Mon Jul 24, 2006 10:09 pm
:lol:
JBT
Postby JBT » Mon Jul 24, 2006 10:19 pm
There are some small screws that hold the headlight unit lid on. You can loosen them which will also give some adjustment.
desertfox
Postby desertfox » Mon Jul 24, 2006 10:24 pm
JBT wrote:There are some small screws that hold the headlight unit lid on. You can loosen them which will also give some adjustment.
How do I get to those screws? Do I remove the black plastic panel that surrounds the actual headlight?
kitkat
Postby kitkat » Mon Jul 24, 2006 10:45 pm
yeah remove the 4 screws on the light cover then there should be 4 screws holding down the lid/cover.
desertfox
Postby desertfox » Mon Jul 24, 2006 10:50 pm
Thanks! :)
