Rust in an MX5
fig
Postby fig » Fri Jul 21, 2006 4:18 pm
nope.......got no salt here :P
Even when I lived by the beach.....2 x MX5's and no rust! (1 NA & 1 NB)
Then
10AE (#3062)
Now
'08 Porsche Boxster S modified ;-b
'11 Porsche Cayenne 22's FTW
'78 Porsche 911SC - Old Skool Hotness
'67 Porsche 912 - Fav!
chrislevingston
Postby chrislevingston » Fri Jul 21, 2006 5:31 pm
The windscreen guy found extensive rust in my A pillars when he went to replace the windscreen (it had been replaced before).
The panel beater who cut it out said that windsceen replacements need to be done well, or this will happen.
The windscreen guy then used different rubber than usual.
Amanda
Postby Amanda » Sun Jul 23, 2006 1:15 pm
Wasn't there a guy in the MX5 club of Vic that had a rust problem with his NA and ended up getting a full respray done at the cost of Mazda??
Lucky_Luke
Postby Lucky_Luke » Mon Jul 24, 2006 10:35 am
I too have had no issues with rust..
but have heard of a few minor cases of the front quarter panels rusting down the bottom on really early NAs just behind the front wheel, after/during winter you'll find a huge amount of crud stuck in there between the quarter and the body and I try to make an effort every year to undo the three bolts down the bottom and empty out all the leaves and dirt etc and re fish oil in there.
U'll be surprised how much stuff accumulates in there. :shock:
L.
CT
Postby CT » Mon Jul 24, 2006 4:32 pm
There shouldn't be too many rust issues as the bodies are zinc coated prior to painting. Although, I reckon the at risk areas as as lucky luke mentions the lower front guards, the upper rear inner guard (behind the seat belt towers) where the drain holes are, around the battery mount if an unsealed battery were ever used, and maybe bottoms of doors if drain holes are blocked.
Generally, anywhere water can sit is prone to rust hence the poor windscreen jobs can lead to rust. Generally drilling into the sills to rustproof a car exposes the raw uncoated steel and if not touched up, will promote rust rather than prevent it. Tectyl is a good product to use if you are hell bent to rustproof as it's thick enough to provide long term protection whereas fish oil is quite thin and should be re-applied much more frequently.
