Some advise please for a MX5 newb (immobiliser)
- CT
- fig
Welcome,
From my experience with these, the NB8A has a factory immobiliser built into the actual key! To cut new keys, you need to purchase direct from a Mazda Dealer (about $25 per key), get the key cut by a locksmith, then take it back to Mazda to get coded to the car.
Now, because you dont have previous documentation, the Mazda dealer will have to request (from Japan) the code for your car. When you go in initially to get the key, they will need to do this as it takes a few days (there may be a charge?).
It is little bit of messing around but its not that bad.
The Alarm pad will have three blue buttons if it is factory, and will say Mazda on it. If it doesnt.....cant help you, if it does....a Mazda Dealer will help you with quesries no worries!!!
Good luck
Good luck
Then
10AE (#3062)
Now
'08 Porsche Boxster S modified ;-b
'11 Porsche Cayenne 22's FTW
'78 Porsche 911SC - Old Skool Hotness
'67 Porsche 912 - Fav!
10AE (#3062)
Now
- Alf
Nerner,
I believe all NB8As came with a factory immobiliser that doesn't need a remote, it's built into the key.
Do you have a key with a fat rubbery plastic top? If so, you've got a factory immobiliser which is built into the lock and key. The car can't be started without one of the original keys (or one programmed in by a dealer). You shouldn't need an immobilizer unless someone steals your keys (in which case, they'll likely have the immobilizer fob anyway.
Hope this helps,
Alf
Hope this helps,
Alf
2015 ND MT GT Crystal White Pearl Mica (pic to come)
- fig
Alf wrote:Nerner,
Hope this helps,
Alf
Sounds better when you say it Alf??????
Then
10AE (#3062)
Now
10AE (#3062)
Now
- bigdog
- King of the kennel
- bigdog
- Alf
fig wrote: Sounds better when you say it Alf??????![]()
Sorry I didn't credit you fig. It didn't seem to have gotten through the first time, I thought a little rephrasing might help.
Alf
- fig
Alf wrote:fig wrote: Sounds better when you say it Alf??????![]()
Alf
I FIGured as much
Then
10AE (#3062)
Now
10AE (#3062)
Now
- maxwolfie
nerner wrote:Thanks
Bevan
Oh my GOD!! Not another one!! *runs*
'89 JDM NA6 (black)
2" s/s ex., 4-2-1 extractors, high flow cat, RX-7 AFM + pod, lightened fly, h/d clutch, 2 way lsd, slotted rtrs, Racing beat type II front bar, Speedy 17" wheels
- fig
nerner wrote:I have two different remotes neither looks like the one in the photo. One has two buttons (one big one small) and the other had a single button with the word vision on it (The vision one does not do anything at all). I traced some of the wiring and found a control box zip tied to the wiring loom so I am now pretty sure that it is all after market.
Thanks to everyone that offered some advice.
Bevan
Definitely aftermarket ALARM then, but immobiliser will be factory (as stated earlier, built into the key). Dont waste time and money worrying about another immobiliser, just get the alarm going/replaced!
R
Then
10AE (#3062)
Now
10AE (#3062)
Now
