Patchy's Fawlty Towers risk management. Enter at own risk
StanTheMan
Postby StanTheMan » Fri Jul 07, 2006 11:00 am
Ok....its begun
The \"almost stock 1.6\" is getting a paint job.
firstly is the bumperbar. Its currently white. It had started out as a classic red & the current paint is peeling off. so figure, its not a good start to use it as a base. So all the current paint has to come off.
Whats the best way to strip the paint off without sanding too much as i figure if i sand it all off its going to pretty hard not to get it wavy. In some parts it will peel off.
this is how it looks currently.
i'll be bleeding the knowlege base on this forum a fair bit.....so any help will be apreciated.
:mrgreen:
STM.
Garry
Postby Garry » Fri Jul 07, 2006 12:58 pm
You can get dedicated bumper paint stripper. It removes the paint without damaging the plastic bumper cover. It comes in a spray can and is available at specialist automotive paint suppliers.
Adam_NAclubman
Postby Adam_NAclubman » Fri Jul 07, 2006 7:51 pm
Since some of it is peeled off anyway, just hit it with the high pressure spray at a carwash, it'll peel the rest of the paint off easily
EGG80X
Postby EGG80X » Fri Jul 07, 2006 8:20 pm
Is Stefan going to be our new DIY King?
StanTheMan
Postby StanTheMan » Fri Jul 07, 2006 10:55 pm
Well I ended up putting elbow grease into it. Its turning out OK. Got just a litte less than half done. As I'm sanding, the loose bits just come off anyway. Looks like this is going to take quite some time to do the whole car.LOL
This bumper has had 2 coast of white & 1 coat of red.....with primer under each ..... Ohh well its all comming off. :mrgreen:
as for DIY King....Not sure there Eggbox.....astro & Steve818 have done thiers too. they both deserve standing aplause.
StanTheMan
Postby StanTheMan » Fri Aug 18, 2006 11:07 pm
well the bumper is finally on. As well as the light cover & front side panel.
The bumper ended up being a different bumper than the one above.
This one has the original paint which is flexible. So none of the paint chipping & cracking issues once its sprayed....... But ......it also has some added bling :mrgreen: :mrgreen: 8)
Check out the ultra cool Air Duct...
broken link
Ladies & Gentlemen....let me assure you....it is totally useless. But ohhhh..the brag factor :mrgreen: :mrgreen: 8)
Thanks to lowmiata, & Mr_Q for thier bits.
I've started talking to the local paint suplier who is more than happy to help. So....Its all good. A fair bit of prepping work is still required.
Also the lining up is with fenders , bonnets & light covers is proving to be a little headache for me. Ohh well......maybe the next Dodgy Day :mrgreen:
Postby Okibi » Fri Aug 18, 2006 11:59 pm
With all those mismatched panels, your d0ri d0ri spec reputation will be intact.
StanTheMan
Postby StanTheMan » Sat Aug 19, 2006 12:00 am
Bunta...... :lol: :mrgreen: 8)
Postby Okibi » Sat Aug 19, 2006 12:16 am
is that Bunta as in InitialD or as in Bunting Armco?
lowmiata
Postby lowmiata » Sat Aug 19, 2006 10:37 pm
just glad to see the stuff go to a good home :mrgreen:
EVI15 1998 to 2008
Mr_Q
Postby Mr_Q » Sun Aug 20, 2006 10:08 am
lowmiata wrote:just glad to see the stuff go to a good home :mrgreen:
Likewise. :)
What colours are you painting the rear? :D :D
Mister Q
Spranga
Postby Spranga » Sun Aug 20, 2006 11:02 pm
I don't think MX5's make very good Taxi's but yours is doing a good impression at the moment Stan :P
Seriously though mate it is good to see it is progressing well. I am impressed with your skill as I believe lining up the front end of an NA is hard with so many angles around the cone and pop-up lights.
Are you any good at removing hail damage????
Dan
StanTheMan
Postby StanTheMan » Mon Aug 21, 2006 8:45 am
spranga....replacing panels is easy. I'm sure you can do it too. Just getting them lined up is the hard bit. :lol:
nath
Postby nath » Mon Aug 21, 2006 7:09 pm
STM,
Let me know if you need help sanding back and doing prep work. Always willing to lend a helping hand.
Nath
Andrew
Postby Andrew » Tue Aug 29, 2006 6:50 pm
You could continue the black theme and end up with something like this :mrgreen:
