Painting Brake Calipers.....
- Roderic
Hi All,
I just thought about the idea of painting my new clalipers since they are not on the car yet. Anyone done it/or have any advice? What type of paint ect.....
Was going to get some crinkle paint for the rocker cover too.....
Regards
Rod.
Regards
Rod.
Thanks to:
Alberts Car Stereo-Fabrication/Stereo
Imports 101-Compliance/Mechanical
Miata Mania-Various
MX5 Mania-04 NB Interior
MX5 Plus-Engine, Gearbox, Brakes, Diff
MX5 Parts.UK-Rear Tail Lights
Prestige Motorsport-Importing
Wheelspin-Mechanical
Miata Mania-Various
- ducktape69
- sab
I've used the VHT spray can stuff. Calipers were off the car, so it was easy to clean them up and spray them. Paint started peeling, flaking and discoloured after 6 months.
I ended up painting over them with a tin of cheap enamel paint worth $5. It's now been 6 months and they still look great!
If I had a choice, I'd be powder coating them next time.
- Roderic
Thanks for the tips guys, they are off the car ATM as going to do a 1.8 conversion. So was thinking of painting them before we fit them
Thanks to:
Miata Mania-Various
Miata Mania-Various
- ducktape69
well i also used the vht spray can stuff and its been fine everyime ive done them on a car. the trick is to make sure u clean teh crap out of them first and spray plenty of light coats
- Roderic
- Mr_Q
Roderic wrote:Any tips on cleaning?
Some wire brushes, can of brake cleaner and a bit of elbow grease.
I did my original NA6 calipers with a can of the VHT brake paint. It lasted a year and still looked fine when I swapped them for the bigger ones.
Mister Q
- ducktape69
- Bevan
- FUN-29T
- bigdog
- King of the kennel
- irwin83r
this is very worth while changes the car totaly. i went a step further to do this.
two cans of VHT, roll of masking tape and a razor blade/scalpel (and some metho and kero to clean
find Mazda logo somewhere on the net (google images) print it out
masking tape the mazda logo to a piece of plastic or card board and cut it out to make a template (fiddly but take your time) out of the masking tape (found using two layers of tape can help)
CLEANING!--> clean with kero then lastly with metho or thinners kero petrol and disel will leave a film or greasy coat and wont leave a good surface for the paint to bond too. things like thinners and metho in particular will evaporate mostly and leave a good surface to paint on. i used kero as its good at eating away grease and grime and metho after as its good at eating away kero
mask up claipers (cover lines and fittings etc) paint brakes backing colour and let dry! (give it a good coat or two)
then place on template (template being the outter part of the tape... you should have tape covering all but what you want the logo to look like
) and cover/tape over all other surfaces and paint on log. give it just enough coats so the backing colour dosnt show through.
peel off the template and tape and smile
would look great red with wihte letters too! and you can do it to your already painted calipers
what colour car you have?
- Garry
