Working windblocker with BD rollbar
Posted: Wed May 10, 2006 5:36 pm
I did it with cable ties.
It sit behind the diagonal bar (on the NB version) an in front of rear supports.
First, you need to take the end caps off either side of the windblocker. Take the brackets off by undoing the nuts. Then, you unsrew the two screws on either end that clamp the plastic bit down onto the net. You take off the plastic bit and screw the net back on. This allows you to get as far forward as poosible towards the diagonal bar.
Place the windblocker behind the diagonal bar by moving the driver's seat forward and sliding it underneath the joing next to the driver's head.
Then onto the cable ties. They need to go between the roll bar base and the pastic trim on the seat belt towers. I managed to JUST squeeze them through. You'll need one cable tie for the top, and two for the bottom. Poke the between the bar supports and the plastic trim and then into the vacan holes left from the brackets on the windblocker The cable ties should look like this on the driver's side.
For the passenger side, I just looped the lower cable ties around the diagonal bar (no picture sorry). The cable ties can't be seen when the seats are reclined so if you're worried about the look of it, don't be.
Anyway, once you've done it for each side, that's it! The end result should look like this:
Best of all, it is fully functioning, so I can put it up whenever I need to, which isn't often. It is a tight squeeze on the passenger's side but it will still go up just fine. Second best of all, is it doesn't rattle.
Enjoy!
Enjoy!
