gregord wrote:I finally discovered the source of an annoying squeak. The bonnet restraint has worn a groove in the back of the holding bracket on the bonnet.
This bracket is rivetted into the aluminium bonnet of my 90 NA.
I have placed felt pads on the bonnet but only stopped the rattle when I bound the bracket in tape.
Anyone have an idea on how I might be able to permanently fix the groove?
I had exactly the same prob on my previous 5. I too bound the bracket with cloth backed heavy duty tape. I never did get around to a permanent fix, I just replaced the tape every couple of months. My current 5 was starting to do the same thing, I moved the bonnet restraint bracket to reduce the movement and stop the groove from developing further.
At the time my thoughts for a permanent fix were, drill out the rivets and find a replace bracket at a wreckers, or build up the metal on the restraint somehow
J
